vht flameproof coating... jet-hot coating alternative... what do you think?
Old Sep 20, 2004 | 06:33 PM
cornhusker's Avatar
Default vht flameproof coating... jet-hot coating alternative... what do you think?
i was just curious to hear what you guys think of the flameproof coating from vht. i know that its not going to be as good as a coating from jet-hot. i also know that it is a different process (spray on versus chemical bonding). but do you think it is a 'next best' option for the budget builders? lemme know what you think.
Old Sep 20, 2004 | 06:36 PM
D-Man's Avatar
Default Re: vht flameproof coating... jet-hot coating alternative... what do you think? (cornhusker)
its good if you dont drive the car...mine lasted a couple hundred miles before it started peeling off
FOrSfEd's Avatar
From what I hear and have seen if done right that stuff works very well. I've been thinking about it myself for the time being.
Old Sep 20, 2004 | 06:47 PM
cornhusker's Avatar
Default Re: vht flameproof coating... jet-hot coating alternative... what do you think? (D-Man)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-Man &raquo;</TD></TR><TR><TD CLASS="quote">its good if you dont drive the car...mine lasted a couple hundred miles before it started peeling off </TD></TR></TABLE>
i am curious, did you apply it according to the instructions? (clean, prep, prime, paint, cure, paint, cure, paint, cure, etc)
Old Sep 20, 2004 | 07:06 PM
m3bluegsr's Avatar
i have high temp paint and it looks good for quite awile. It last forever how long until the manifold rust through. i did prep and cure correctly though...when i didnt it peeled like in the first couple days.
blaxican05
Sep 23, 2005 10:13 PM
Catch 22
13
Aug 29, 2005 03:59 PM
Luke
Honda Motorcycles
14
May 4, 2005 08:18 AM
