Please help me with compustar install PICTURES
QUestion noob at this.
the red wire(power) goes back to the harness to the brain, were does the blue and the purple wire go to?
The yellow wire goes to the starter, were does the other yellow and the yellow/black wire go to?
the red wire goes back to the harness as a starter wire
another look
Please help its for a 93 civic ex. compustar 2wss
another look
those are just relay's, i am assuming you are using a relay for the starter and one for the clutch or what?
Do a search on the internet as far as what each wire is.
I'm assuming that the second pic is a starter kill relay? If so, you'll need to cut the starter wire, and the yellow wire goes to the starter side of the cut wire, and another wire goes to the key side...
You need to get yourself a manual to get the color codes right...
ok i figured out the yellow wires were for the relay for the inition.
now the red wires
i know the red wire with the fuse goes straight to the 12volt red wire...done..
now i have a slot call 12 volt constant, prewired relay for 2nd lg, acc or starter thats what is in the first picture...
Theres the harness the lower left is 9volt stright...
now the next one over theres 2 wires comming out, one goes to the relay in pic #1 in the thread, the other comes out to just a plain red wire. like in this pic shows all 12 volt wires.
i got the the red wire on the left but do i need the 2 red/white wires from the harness?
now the red wires
What's the model number on your unit?
You need to go to http://www.compustar.org/support/index.html and download a manual and read it. It'll tell you what wires go where.
Ditch that relay for 2nd starter crap. Cut it off and just make sure both 12v wires on connector 1 are connected to a constant 12v source. By "both" I mean wire 1 and wire 2...and not 2 red/white wires...
ok yeah i got all that **** taken care of.
now im on the actual hooking all the door locks and triggers n ****.
couple of questions
do i need to hook up my backup battery to this compustar unit, i got the power all hooked up and a gropund but i needto hook it up to atrigger...a (-) trigger so should i do the door locks, hood pin, trunk trigger, door trigger or what? whatwould be best?
ALmost done mabie another 2 hours
couple of questions
colnago
Audio / Security / Video
17
Nov 29, 2006 11:00 AM
