Blowing out the spark on a semi-high hp setup....
Old Sep 20, 2004 | 03:48 PM
servion's Avatar
Default Blowing out the spark on a semi-high hp setup....
Well, I'm having a problem with blowing out my spark... I think. I went to the track yesterday (I won the SWFD 1st place trophy!!! ) and I was having troubles.
What would happen: I was boosting smoothly. The car made 524whp @ 22psi. I turned it up to 25psi and the car would buck badly... and the boost gauge would be all over the place. I changed the plugs and got one more good pass out of it at this boost level. The next pass: bucking again. The datalog of the engine load confirmed this... its was quickly going in and out of boost, and it was bucking like mad.
I eventually fixed it by turning down the boost a few psi (23-24 or so) and tightening the plug gap down to 16 thousandths from 18 thousandths. Running NGK 8 heat range plugs. This plug gap seems tight to me in the first place, but its what my car likes for some reason. I'm running a MSD SCI with a blaster 2 coil. Would a better coil help me out?
What kind of ignition system would you suggest for a ~600WHP car? I'm planning on getting to 650-700 whp as an end goal, so I'd like something that will support me to that point. I would consider some sort of distributorless system if that would help out (I'm currently running the AEM EMS)... I've heard that some of those distributorless systems have let a lot people open up their plug gaps significantly.
Old Sep 20, 2004 | 04:07 PM
Antilag's Avatar
Default Re: Blowing out the spark on a semi-high hp setup.... (servion)
16 seems kinda low, i do fine with 18 thou boosting 26. On your datalogging, what was your a/f at peak boost? what's your timing maps set at? and also what size injectors are you using? how is the injector duty cycle on your datalog at peak boost?
Old Sep 20, 2004 | 04:08 PM
Antilag's Avatar
Default Re: Blowing out the spark on a semi-high hp setup.... (9sech22civic)
I would use the 9 series injectors personally.
Old Sep 20, 2004 | 04:11 PM
servion's Avatar
Well, I'm running 1000cc injectors with a wlbro 2545hp intank and an old dragIII inline. Timing is at 17.8 degrees... and the a/f is around 11:1. Not sure on duty cycle... I'll have to look, but I don't think they are maxed out... I'm making ~524 corrected whp at ~6000feet elevation with 1000cc injectors at a base fuel pressure of 43psi
Old Sep 20, 2004 | 04:45 PM
*Boostwerks*'s Avatar
I would try out the R5671A-9 plugs Stock # 5238, before you try anything else.
Tony1 reccomended these to a setup that was blowing out the spark at high boost and they solved the problem. All he was running was a blaster coil.
I would just try those out before changing anything.
Old Sep 20, 2004 | 05:50 PM
Antilag's Avatar
Default Re: (Bryson)
exactly, that is what i use.
slowteg550
Jul 5, 2006 03:04 PM
victoriasamantha
Mar 19, 2006 04:39 PM
torr
Aug 29, 2004 01:06 PM
B_1_8_hatch
Dec 2, 2003 03:13 AM
turbo Si
Apr 24, 2003 08:34 PM
