Dyno question???
I got a lot of stuff in my car but this is actually the ones that you can tune...
Vafc
Cam gears
Fuel pressure regulator
and of course ,timing
I'm just wondering if there is any specific order to tune them (Ex. cam gears first,vafc second etc etc)?
Vafc
Cam gears
This is just my opinion and every tuner will have his own...
On our dyno we set the timing first, make a few bass runs to check the air/fuel. We then set the fuel pressure and try to establish the perfect "base" After that the Vafc will help fix small problems on the air/fuel and also help figure the best spot for vtec. Remember that changing cam gears also changes ovewrall crank timing.
Good Luck
Good Luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4cylinder »</TD></TR><TR><TD CLASS="quote">not to high jack
but do u dyno guys
dyno in second or third gear 4 power?
as 4 tuneing is third best?</TD></TR></TABLE>
I would like to know this too!
but do u dyno guys
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4cylinder »</TD></TR><TR><TD CLASS="quote">not to high jackbut do u dyno guys
dyno in second or third gear 4 power?as 4 tuneing is third best?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid_vtec »</TD></TR><TR><TD CLASS="quote"> would like to know this too!</TD></TR></TABLE>
Just my opinion - we do all cars in 3rd that make 200-250hp When the cars just higher in power like 300 + we use 4th. It helps stretch out the graph so we can tune better.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RageDzine »</TD></TR><TR><TD CLASS="quote">
Thanx!
Thanx!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RageDzine »</TD></TR><TR><TD CLASS="quote">Very welcome -- Good Luck</TD></TR></TABLE>
Thanx
Thanx
