Is my fuel pump going bad? Questions about the fuel systems on 3rd gens.
Old Sep 19, 2004 | 11:39 PM
Mt3c's Avatar
Default Is my fuel pump going bad? Questions about the fuel systems on 3rd gens.
For the past year or so, whenever i refuel my car, usually about 11 to 12 gallons worth, the car will run for a little bit then die. I've ignored it for a while, but it's getting quite annoying now.
Now I know to listen for the fuel pump to pressurize or whatever it does, it makes a whirly sound. But right after i refuel it doesn't do that immediately. I would have to wait 1 to 10 minutes before i can get the fuel pump to make that sound, then i can be on my way.
Now if my fuel pump is going bad, why does it smoothly work after the initial hiceps of refueling.
And also, what does the main relay do, and what happens when it goes bad.
Another question, what happens when injectors go bad.
hopefully i can get some good responses, thanks in advanced.
ps, car is 1994 integra with over 170k miles
Old Sep 20, 2004 | 12:16 AM
SwedBoy2999's Avatar
Default Re: Is my fuel pump going bad? Questions about the fuel systems on 3rd gens. (Mt3c)
if it's on warm days and your interior is hot then i would take a look at the main fuel relay since they are known for "making the car just die" and it taking a little while for it to start up again. Inside the relay some of the prongs that are soldered onto the circuit board have a tendency to kind of crack or break especially when the interior is hot. I took mine apart and soldered the prong better and i've never had the problem since. Just search it and there are threads that talk about this problem more in depth. Just my .02 cents.
Old Sep 21, 2004 | 09:47 AM
Mt3c's Avatar
Default Re: Is my fuel pump going bad? Questions about the fuel systems on 3rd gens. (SwedBoy2999)
thanks for the pointer. after doing some searching, i think it is the main relay. happened again yesterday, felt for clicking on the main relay and none. then it was good. gonna try to solder it today.
got_no_sol
Mar 31, 2017 06:32 PM
ALTERED4
Jan 31, 2009 08:43 PM
4doorcivic9
Jun 11, 2008 06:31 AM
boostnubII
Oct 21, 2006 06:42 PM
lsvtecrocket
Sep 8, 2003 03:51 PM
