Which Exhaust System Should I Use?
Old Dec 10, 2001 | 01:04 PM
RicerRacing69's Avatar
Default Which Exhaust System Should I Use?
I'm doin a b18c1 swap into my 93 civic HB this month and I don't know which aftermarket catback to shop for; a gsr, since the engine is a gsr, or a civic HB, since the body is a civic HB? Could you guys help me out, thanks.
Old Dec 11, 2001 | 11:59 AM
3.3.3's Avatar
Default Re: Which Exhaust System Should I Use? (RicerRacing69)
a muffler shop can cut & weld to fit your car. what header are you using? you might want to look into a JDM-R exhaust mani. you will need a 2.5 collector. the piping should be 2.25-2.5 for all motor. 3 for turbos.
Old Dec 11, 2001 | 12:11 PM
Default Re: Which Exhaust System Should I Use? (maks)
I'm using the stock JDM header from the GS-R engine right now, later i will put a dcsport 4-2-1 header. So basically your saying i can't buy an aftermarket exhaust sys., i have to have one customized?
Old Dec 11, 2001 | 03:23 PM
90accord1's Avatar
yes you can get one for your car, jsut get one for yoru exact car, you might need some modification done to the cat though but thats about it, if your lucky itll all bolt up
Djole_V
Jun 23, 2007 02:23 PM
shhh151
Jul 30, 2004 11:23 AM
kay_animation
22
Oct 3, 2003 08:02 AM
Fuster_Cluck
Nov 7, 2002 12:57 PM
VWkila
Apr 9, 2002 08:15 PM
