Throwout Bearing same for cable/hydro?
not sure if they are the same. the spline sizes are definitely different between the two. hydro being the larger of the two. The T/O bearing should be the same for both though. Found that to be the case when swapped a b16a into my 91 si. had the wrong clutch disk, but didnt have to change out TO bearings.
chaz
chaz
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NeoGSR »</TD></TR><TR><TD CLASS="quote">what b-series tranny uses a cable?</TD></TR></TABLE>
DA's and the early B16 trannys are cable
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iwhichisme »</TD></TR><TR><TD CLASS="quote">not sure if they are the same. the spline sizes are definitely different between the two. hydro being the larger of the two. The T/O bearing should be the same for both though. Found that to be the case when swapped a b16a into my 91 si. had the wrong clutch disk, but didnt have to change out TO bearings.
chaz</TD></TR></TABLE>
so the throwout bearing is the same? does anyone have a pic of a throwout bearing for the hyrdo tranny?
