What Clutch do I use?
Old May 22, 2006 | 12:29 PM
JDM_EK_JOE's Avatar
Default What Clutch do I use?
What clutch do I use for a B16 cable Trannie going onto a B18c1 Block?
Old May 22, 2006 | 01:03 PM
si90rex's Avatar
Default Re: What Clutch do I use? (91Civic_Joe)
all b-series clutches are the same u can put a hydro clutch in a cable tranny the only difference is the throw out bear. hydro clutch with cable throw bearing will work just fine, you can get a 90-99 bseries cluth just buy a new cable throw bearing. its the same with a D-series as well.
Old May 22, 2006 | 02:43 PM
JDM_EK_JOE's Avatar
Default Re: What Clutch do I use? (si90rex)
So i can actually use my D-series cable trannie throwout bearing in a b series cable trannie?
Old May 23, 2006 | 04:56 AM
si90rex's Avatar
no like if you have a dseries hydro clutch and you have a dseries cable tranny than it will work the only thing that b and d series share is the bolts
bseries spline are way bigger than a dseries
for your bseries you need either a
B series:
cable throw out bearing
and either or a hydro or a cable clutch
the differents between a cable tranny and a hydro tranny is the throw out bearing
TJChad
Oct 11, 2010 10:07 AM
EJ1Turbo
Dec 5, 2008 08:14 AM
EG6-SIRII
Feb 3, 2006 06:59 AM
SnowSurfer
10
Jun 15, 2005 01:57 PM
hondasniper
Sep 23, 2004 03:38 PM
