GSR Build ?'s
Old Sep 19, 2004 | 01:13 PM
ferio 95's Avatar
Default GSR Build ?'s
Ok i spun a rod bearing on my gsr motor so ive decided to rebuild it a little since i had the cash. I want to put a ls crank and rods with a set of PCT pistons. From the compression calculator on c-speedracing.com that puts my compression at 12.2-12.3.
Now my questions are
If anyone has done this, how serious is the valve clearance?
What can be done to fix it if its to close?
Im going NA so would the LS rods be ok with just some ARP rod bolts?
Will GSR oil pump, pickup, stock girdle be good enough to safely rev at least 8k?
Will the oil squiters need to be removed or shaved?
What type of tuning would you recommend?
Anyone dyno'd this setup before?
Old Sep 19, 2004 | 05:16 PM
ferio 95's Avatar
Default Re: GSR Build ?'s (ferio 95)
bump
Old Sep 19, 2004 | 05:22 PM
BrokeAssWhiteboy's Avatar
my house has wheels on it
i.m.o. gsr > ls
Old Sep 19, 2004 | 08:58 PM
ferio 95's Avatar
Default Re: (BrokeAssWhiteboy)
if you think a stock gsr would own this setup your smoking good ****. im not loosing anything over a stock gsr.
Old Sep 19, 2004 | 10:27 PM
rjay8604's Avatar
Default Re: (ferio 95)
how did you spin the bearing or what happened?
Old Sep 20, 2004 | 05:15 AM
jdm_ef9's Avatar
Default Re: (rjay8604)
gsr w/ pct's own!!!
Old Sep 20, 2004 | 07:23 PM
ferio 95's Avatar
Default Re: (jdm_ef9)
lost a **** load of oil in 2 days from a leaking valve cover. a real careless mistake on my part
Old Sep 20, 2004 | 08:44 PM
HONDA_TYPE_R's Avatar
OUCH!!! I have heard that clearance with CTR's is close. Every post I see concerning this always has someone saying "clay the motor". So there I guess I'll be that one person.
I have heard that with higher lift cams, you may be a little too close for comfort. That could prove disastrous if timing went off just a **** hairs worth.
Old Sep 20, 2004 | 09:25 PM
ferio 95's Avatar
Default Re: (HONDA_TYPE_R)
yea ive read that several times and i plan on running some badass cams down the road so i dont want that kick in the butt
Old Sep 20, 2004 | 09:30 PM
rjay8604's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ferio 95 &raquo;</TD></TR><TR><TD CLASS="quote">lost a **** load of oil in 2 days from a leaking valve cover. a real careless mistake on my part</TD></TR></TABLE> oh man, at least you know it was something you could of prevented, instead of something mysterious that you can't sleep at night becuase of.
Old Sep 21, 2004 | 01:21 PM
rcurry14's Avatar
you are losing a better rod/stroke ratio.
Old Sep 21, 2004 | 08:16 PM
ferio 95's Avatar
Default Re: (rcurry14)
that whole r/s stuff is garbage. it does have some key points but there is a difference between a motor that hauls *** and one that is moderatly quick that has a great stroke. I might be getting a Si shortblock to toss my gsr head on just to have my car running again. But isnt my car to heavy for a tourqeless motor?
Old Sep 22, 2004 | 12:31 PM
rcurry14's Avatar
Yea its not to big of a deal when you put a rod through the side of you block dont sweat it you can just glue the pieces back together within a couple of hours.
Old Sep 22, 2004 | 01:58 PM
hybrid_vtec's Avatar
As far as putting LS crank and rods in a GSR! Why not plenty of ppl do and the LS has a longer stroke(89mm) and it will raise your compresion and yield more torque! CTR Pistons sounds good, but beware there are clearance issues and you will have to clay the motor, but it shouldnt be a big deal, just dont run a thinner headgasket!
Another issue with the LS internals in a GSR you have to watch how high you rev that motor b/c the LS bottom end want mean to go to 8K but that doesnt mean you can't! Get some ARP Rod Bolts and talk to someone at a local machine shop and see what they can do!
leroyb
May 6, 2009 07:13 PM
cptengineer
Mar 22, 2006 02:04 PM
DShowers
Dec 6, 2005 06:44 PM
delslow94
Mar 1, 2003 12:24 PM
