turbo manifold on B16a with 2 O2 sensors
Hi! I have a CRX SiR Euro with B16A cables that is with 2 o2 sensors.
1 on cyl 3 and 1 on cyl 2.
Now i have a equal lenght turbo manifold without any place for the sensors. Can I just make 2? Or is it going to be to close to the flenge? To hot?
Any other tricks?
Thanx
Any other tricks?
Thanx
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiKid86 »</TD></TR><TR><TD CLASS="quote">o2 simulator.</TD></TR></TABLE>
whats that?
whats that?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiKid86 »</TD></TR><TR><TD CLASS="quote">it makes your engine think a o2 sensor is there but its not.</TD></TR></TABLE>
sounds nice....can you link me one of those?
umm im not to sure on where to get them, but If i were you i would try to get a bung welded in. It would only cost 20 bux max... Get a bung or 2, have a shop drill some holes and weld it in. Then you can use your exisiting wires (might have to make em longer) and use real o2 sensors
isn't it risky to put the sensors before the turbo? particles from the sensors kan drop into the turbo..and then blow it up..
anyone that tested to put the 2 sensors on the down pipe...without any troubles?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crispydee »</TD></TR><TR><TD CLASS="quote">Ive got both sensors in my down pipe, they need to go in after the turbo. Im not having any problems with it. well apart from smoking but that not o2 linked.</TD></TR></TABLE>
what type of car, year, engine?
