Flashing light in ecu
Old Sep 18, 2004 | 08:17 AM
ineedmoney's Avatar
Default Flashing light in ecu
What is the flashing red light in the little window on my ecu. Stock 88 rex. I was thinking that it was a code thing not sure tho. Thanks ahead for the help
Old Sep 18, 2004 | 08:22 AM
RCautoworks's Avatar
Default Re: Flashing light in ecu (ineedmoney)
Its a code, read the amount of times it flashes. 1 long flash is 10, shorts are 1 and then get back to us. By the way, where sunglasses or else the flashing dot can cause blindness.
Old Sep 18, 2004 | 08:25 AM
chambersef8's Avatar
Count how many times it flashes, and that's what code you are throwing. Pick up a Helms manuel at AutoZone or similar store. The manuel will tell you what each code means.
My good deed for the day
Old Sep 18, 2004 | 08:40 AM
ineedmoney's Avatar
Default Re: Flashing light in ecu (90blackcrx)
there are 15 flashes, what code is that??
Old Sep 18, 2004 | 08:49 AM
crxgator's Avatar
15...
ignition output signal...either a short in your distributor wiring, a new ignitor, or a new ecu...
Old Sep 18, 2004 | 08:53 AM
ineedmoney's Avatar
Default Re: Flashing light in ecu (crxgator)
how does that affect my car?
ineedmoney's Avatar
effect
mikeszutu
Sep 12, 2008 03:08 AM
supaf1y
Jul 3, 2007 06:08 PM
BLUE EH3
Jan 12, 2007 01:00 PM
brega3
Jun 30, 2003 03:43 PM
