eliminating wheel hop on EP3
Old Sep 18, 2004 | 01:53 AM
kani's Avatar
Default eliminating wheel hop on EP3
Any help from energy suspensions or mugen bushings or maybe ingalls engine damper/stiffer engine mounts? I'm starting to get really frustrated with wheel hop.
I now have a quaife lsd and kw suspension, the wheel hop is making me crazy!! Sometimes it launches really well and well sometimes... ARGH! I try my best to avoid it but still..
No radius rods for the EP etc. like on the EG civic?
Old Sep 18, 2004 | 06:05 AM
Lucid Moments's Avatar
Default Re: eliminating wheel hop on EP3 (kani)
From what I understand the ES motor mount inserts will do the job, and they are the cheapest solution, but J's racing, and Ingalls both make torque dampeners that will do the job also.
Old Sep 18, 2004 | 09:03 AM
Kal's Avatar
Kal
ES MM inserts are cheap and effective if you like some rattling in the cabin. Mugen has MM replacements which do not add any rattling but are much stiffer. A torque damper is mediocre at stopping wheel hop, the best is the motor mounts. If you have a heavily modified engine, you might want to purchase MM and a torque damper.
Old Sep 18, 2004 | 10:32 AM
dacaveman's Avatar
If you have enough money just go with hasport mounts. Or if you don't, just get motor mount inserts.
Old Sep 18, 2004 | 12:09 PM
EtherGhost's Avatar
Default Re: (dacaveman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dacaveman &raquo;</TD></TR><TR><TD CLASS="quote">If you have enough money just go with hasport mounts. Or if you don't, just get motor mount inserts.</TD></TR></TABLE>
Hasport doesn't make mounts for the EP3
Old Sep 18, 2004 | 02:15 PM
dacaveman's Avatar
O well then just any mount kit that is solid should do the job.
Old Sep 20, 2004 | 10:37 AM
djmota's Avatar
I would get a torque dampner first. if that doesn't do the job then I would get the inserts. I like the dampner idea because when your not racing you can easily take out the bushings and get rid of the vibration for comfortable daily driving. The inserts however are there to stay. I have the insets in my EM2. The rattles can get annoying.
Old Sep 20, 2004 | 10:48 PM
civicvtec1ps's Avatar
Default Re: eliminating wheel hop on EP3 (djmota)
Get engine damper.
Works great and easy to install.
I have es mm inserts sitting in my room and i probably wont install it..
Old Sep 22, 2004 | 12:23 PM
BlaqK20's Avatar
Motor mounts will make ur idle a bit rougher though. Better tires wouldnt hurt either.
Old Sep 22, 2004 | 01:51 PM
Archidictus's Avatar
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kani &raquo;</TD></TR><TR><TD CLASS="quote">Any help from energy suspensions or mugen bushings or maybe ingalls engine damper/stiffer engine mounts? I'm starting to get really frustrated with wheel hop.
No radius rods for the EP etc. like on the EG civic? </TD></TR></TABLE>
Get a new driver and the problem will probably work itself out. Or you could learn how to launch. Just a couple suggestions from someone who knows .
Old Sep 23, 2004 | 12:24 AM
sk8flex's Avatar
What´s more effective? Installing motor mounts or engine damper? Or both?
Old Sep 23, 2004 | 12:38 AM
DC5ITR329's Avatar
Default Re: eliminating wheel hop on EP3 (sk8flex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sk8flex &raquo;</TD></TR><TR><TD CLASS="quote">What´s more effective? Installing motor mounts or engine damper? Or both?
I used to have alot of wheel hop. I had the J's racing td and that was pretty good. but I noticed when you get tires that are good, it doesn't wheel hop that much.
Modified by aznbo1626 at 7:45 PM 9/26/2004
Old Sep 23, 2004 | 11:41 AM
andyep3's Avatar
Inserts completely eliminated any wheel hop that I have.
After 2k miles, the only rattling I get is at idle and with the A/C on and it's 10x more tolerable than having a stiff suspension (which, IMO, is more annoying than a mild rattle in everyday driving).
Plus, the inserts were like $25.
inkong
12
Jan 15, 2007 12:05 AM
elitesi8
Oct 9, 2005 06:42 AM
pentaq
Apr 1, 2003 08:46 AM
JICsube
Jul 21, 2002 06:54 PM
PiYoImuT
Nov 30, 2001 11:48 AM
