how do you open transmission?
Old Sep 17, 2004 | 04:20 PM
apexrift's Avatar
Default how do you open transmission?
I got new internals for my transmission and i need to know how to take it apart to put that **** in. i took off all the case bolts, and its about an inch apart, but it won't budge any further. any ideas? (gears broke inside this transmission )
Old Sep 17, 2004 | 04:22 PM
Super Chicken's Avatar
Default Re: how do you open transmission? (apexrift)
Manual is yur friend
Shiflt linkage is binding you up more than likely unless you did something stoopid like not take one of the external pieces off that the manual tells you to.......
Old Sep 17, 2004 | 04:49 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: how do you open transmission? (Super Chicken)
Did you remove/move the snap ring?
Old Sep 17, 2004 | 05:10 PM
S9i1R's Avatar
on the end of the tranny there's a I think 17mm plug on the end.
remove that and there's a snap ring under that, spread and lift and it's off wiggleing it might help.
Old Sep 17, 2004 | 06:26 PM
B2FiNiTY's Avatar
Default Re: how do you open transmission? (S9i1R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S9i1R &raquo;</TD></TR><TR><TD CLASS="quote">on the end of the tranny there's a I think 17mm plug on the end.
remove that and there's a snap ring under that, spread and lift and it's off wiggleing it might help.</TD></TR></TABLE>
Yep. I suggest getting snap ring pliers to ease the process.
Old Sep 18, 2004 | 12:16 AM
mikerbike's Avatar
Default Re: how do you open transmission? (B2FiNiTY)
I just use two flathead scerw drivers. The plug is 3/8" drive on both of my transmissions (d16 and b18 cable.) Good luck.
Old Sep 18, 2004 | 01:41 AM
t0eKnEe's Avatar
Your gonna rebuild your tranny and you dont even know how to open it??
Good luck
Old Sep 18, 2004 | 06:11 PM
S9i1R's Avatar
Default Re: (t0eKnEe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t0eKnEe &raquo;</TD></TR><TR><TD CLASS="quote">Your gonna rebuild your tranny and you dont even know how to open it??
Good luck</TD></TR></TABLE>
don't listen to him I wasn't sure how to get mine open the first time I pulled mine apart it's not too hard, just keep it in order and keep it CLEAN
Honda3133
Sep 18, 2011 09:08 AM
bfrito
Jan 10, 2011 01:48 AM
jwbnavy
13
Nov 27, 2007 11:19 PM
CRX_1.8T
Sep 24, 2006 07:46 PM
DC_RaceR
Mar 7, 2006 04:18 PM
