SOHC Vtec Wiring
Old Sep 17, 2004 | 03:09 PM
charlesadams's Avatar
Default SOHC Vtec Wiring
i have a 92 dx and i put a 95 si motor in it. how do i wire up the vtec to an off and on switch. so i can use vtec when i want.
Old Sep 17, 2004 | 03:53 PM
Padawan's Avatar
Darth ModerVader
Default Re: SOHC Vtec Wiring (charlesadams)
I'm not trying to be rude, but is this a serious question, or a poor attempt at humor/trolling?
Old Sep 17, 2004 | 03:56 PM
blaster834's Avatar
haha wow. i wouldnt even wire it up in a sohc engine, its a joke.
Old Sep 17, 2004 | 04:10 PM
Padawan's Avatar
Darth ModerVader
Default Re: (blaster834)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blaster834 &raquo;</TD></TR><TR><TD CLASS="quote">i wouldnt even wire it up in a sohc engine, its a joke.</TD></TR></TABLE>
Not a very helpful or informed reply...
Old Sep 17, 2004 | 04:11 PM
murmur9's Avatar
HAHA , funny guy.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by charlesadams &raquo;</TD></TR><TR><TD CLASS="quote">i have a 92 dx and i put a 95 si motor in it. how do i wire up the vtec to an off and on switch. so i can use vtec when i want.</TD></TR></TABLE>
For some reason, I'm questioning if you actually got the swap. lets see (grin) is it a SOHC or DOHC 95 si (i know, do you?)
Old Sep 17, 2004 | 05:05 PM
slotec's Avatar
Default Re: (murmur9)
maybe he meant what he said a 95 si motor the single cam d16z6. help the man out dont be an ***
Old Sep 17, 2004 | 05:14 PM
Default Re: (slotec)
come on now damn im not a f***in *** im gonna run turbo on it i was to that vtec was the equivlent of 2 pounds of boost so i want to have it on the side to see if it even makes a difference. damn i thought this site was hella tight but this is messed up i look for help and i get clowned. thanx alot people
Old Sep 17, 2004 | 05:27 PM
Kyles ej1's Avatar
Default Re: (charlesadams)
well maybe if u used details in your ? u wouldnt be getting clowned. ur ? made u sound like a dumbass. u coulda said wat u just said along with ur original ?
Old Sep 17, 2004 | 05:39 PM
Padawan's Avatar
Darth ModerVader
Installing a switch in the VTEC wire coming from the ECU will accomplish what you're asking. However, keep in mind that, although you'll be preventing VTEC from activating, the ECU will still be switching to the VTEC fuel and ignition maps, which won't be ideal if the engine is being kept on the small lobes.
A much better idea is to simply leave VTEC functioning and have the setup properly tuned.
Old Sep 17, 2004 | 05:46 PM
SOHC4life 96's Avatar
Default Re: SOHC Vtec Wiring (Padawan)
Yeah, dont mess with VTEC, period. It is meant to engage and Honda put it at specific point to take full advantage of its "powers" Just leave it alone is all we are saying.
Edit: put it aT* not a
Modified by DOHC4life at 7:59 PM 9/17/2004
Old Sep 17, 2004 | 06:57 PM
Default Re: SOHC Vtec Wiring (DOHC4life)
ok then
Old Sep 17, 2004 | 06:58 PM
thanks
Old Sep 17, 2004 | 07:18 PM
slambedcivic's Avatar
just leave it be. and since youve gotta 92, its already done right.
if you really wanna know theres a black wire with a blue stripe on it. put an interrupter switch on there. thats the VTEC solenoid ground wire.
efking1985
14
Mar 8, 2007 03:56 PM
95civicz6ex
Aug 1, 2006 05:10 PM
85ES3
Mar 16, 2006 06:24 PM
92hatch420
10
Jan 22, 2006 08:15 AM
koshie
Feb 14, 2003 06:53 PM
