h22 swap won't start
Old Sep 17, 2004 | 11:17 AM
ek9h22's Avatar
Default h22 swap won't start
i have 96 civic cx, i swap the engine to a h22a4 1999 i used civic si wire harness, skunk2 wire converter from obd2-obd1, p13 ecu. i checked every ground wire and check all my connection and still the engine don't turn can any one help me with all info on a swap step by step so i can compare to see what i'm doing wrong...
Old Sep 17, 2004 | 11:35 AM
chad's Avatar
Moderator
Default Re: h22 swap won't start (ek9h22)
what wire harness on the engine did you use??
you know you need it converted to run the h22
Old Sep 17, 2004 | 12:06 PM
92hybridAccord's Avatar
From: In the heart of the ghetto of the, Suburbs NYC
Default Re: h22 swap won't start (chad)
Is the car cranking...does it click on the turn of the ignition...more info needed in order for anyone to help.
Check all grounds and starter wire..for starters
Old Sep 20, 2004 | 05:37 AM
ek9h22's Avatar
i'm using 99 civic si wire harness. i checked all the grounds and still jujst a click and don't start i bypass the starter and the engine still didn't turn
Old Sep 20, 2004 | 05:42 AM
Archidictus's Avatar
Unceasing Measure
Why do you think a B16A2 wiring harness is going to run an H22A4 engine? You need to wire up a resistor box for the fuel injectors, for starters, and you should probably make sure any extraneous sensors are getting information back to the ECU.
Old Sep 20, 2004 | 06:21 AM
GAccord's Avatar
Default Re: h22 swap won't start (Archidictus)
You should of had hasport or hcp rewire the harness. You need to send them the h22a and the b16 wiring harness.
Old Sep 20, 2004 | 08:08 AM
2point2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">You need to wire up a resistor box for the fuel injectors, for starters, </TD></TR></TABLE>
do that first.
Old Sep 20, 2004 | 08:53 AM
eg4matze's Avatar
Default Re: h22 swap won't start (2point2)
h22 engine doesnt work with b16 wires, we had the same problem by swapping. You need the h22 wires
Old Sep 20, 2004 | 10:58 AM
2point2's Avatar
Default Re: h22 swap won't start (eg4matze)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg4matze &raquo;</TD></TR><TR><TD CLASS="quote">h22 engine doesnt work with b16 wires, we had the same problem by swapping. You need the h22 wires
Don't you just extend the 'b16 wires' to the corresponding sensor and add in a resistor box/wiring? Never did this particular swap but you guys are making this sound like the two harnesses are very forien to eachother????
Old Sep 20, 2004 | 11:02 AM
H22JEFFREY's Avatar
THERE IS A LOT OF LIKE CONNECTORS BUT YOU NEED BOTH WIRING HARNESSES TO WORK WITH I HAD TO GO THREW SAME THING BUT IT WAS RIGHT THE FIRST TIME . GET A HARNESS MADE FROM HASPORT
Old Sep 20, 2004 | 02:31 PM
ek9h22's Avatar
that is the only thing i didn't do was the resistor box. does any resistor box from any honda/acura work. i'll let ya know what happen when i connect the resistor box
Old Sep 20, 2004 | 02:50 PM
2point2's Avatar
Default Re: h22 swap won't start (hybridvisionz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridvisionz &raquo;</TD></TR><TR><TD CLASS="quote">THERE IS A LOT OF LIKE CONNECTORS BUT YOU NEED BOTH WIRING HARNESSES TO WORK WITH I HAD TO GO THREW SAME THING BUT IT WAS RIGHT THE FIRST TIME . GET A HARNESS MADE FROM HASPORT</TD></TR></TABLE>
<FONT SIZE="100">THANKS FOR THE INFO BUD - BUT WHEN YOU TYPE IN CAPS ON THE INTERNET IT'S LIKE YOUR YELLING AT SOMEONE!</FONT>
Just so ya know
'sall good.
yeah, doesn't sound overly hard if your comfortable with wiring schematics.
i'm pretty sure all resistor boxes will work the same, you might be able to find one from an older accord at the bone yard pretty easy. unclip the injectors and cut off that whole part of the engine harness, that way you'll keep everything clean.
89sicivic
Jan 3, 2008 07:07 PM
dracos2001
Aug 6, 2006 08:31 AM
SI_SOLDIER
Jan 12, 2004 06:13 AM
