Head Unit too damn bright
Old Sep 16, 2004 | 04:51 PM
blackcivic44's Avatar
Default Head Unit too damn bright
I have a panasonic head unit with the "day and night glow" and at night its crazy bright... anyone know any way to turn it down or something of the sort. Sometimes i drive around with the face down so the light is off.
Old Sep 16, 2004 | 08:03 PM
Corporation's Avatar
Economic Upturn, WUT
From: Alittle Placed Called None of Your Damn Business.
Default Re: Head Unit too damn bright (blackcivic44)
should be a function button that has brightnness, on my pioneer I have to turn the headunit off and hold the function button and then it gives me xtra options
Old Sep 16, 2004 | 10:19 PM
hometheaterman's Avatar
Default Re: Head Unit too damn bright (Sweet Lou)
On my JVC Aresonal I can have it so it is always dim always bright or so it dims when I turn my headlights on. I don't know about yours but mine has those choices. I Don't have a Panasonic though so I don't know about those.
Old Sep 17, 2004 | 07:51 AM
B18C_EJ8's Avatar
There should have been an orange wire or orange/white on the radio harness.. Just hook that up to the dimmer wire in the car, and you can control the brightness with the car dimmer... It should actually automatically dim when you turn the car lights on...
Old Sep 17, 2004 | 04:19 PM
Goatsterrman's Avatar
Default Re: (B18C_EJ8)
Does the Unit get any dimmer when you turn you lights on?
Old Sep 17, 2004 | 09:00 PM
cd5_2NR's Avatar
Default Re: (Goatsterrman)
have you tried wearing sunglasses while driving...
or try tinting that bitch...
Old Sep 17, 2004 | 09:02 PM
Ludeboi's Avatar
those head units are bright as hell
Old Sep 18, 2004 | 04:26 AM
HiRevn's Avatar
Default Re: (Ludeboi)
You should check to see if your HU has a dimmer function. Maybe it's not properly wired up. My Alpine has a dimmer which i wired to the OEM harness, so when you turn the headlights on, the HU automatically dims ala OEM.
Old Sep 18, 2004 | 03:56 PM
B18C_EJ8's Avatar
Default Re: (HiRevn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiRevn &raquo;</TD></TR><TR><TD CLASS="quote">You should check to see if your HU has a dimmer function. Maybe it's not properly wired up. My Alpine has a dimmer which i wired to the OEM harness, so when you turn the headlights on, the HU automatically dims ala OEM.</TD></TR></TABLE>
Is there an echo in here?? Did I not just type the same thing like 5 posts up??
Old Sep 18, 2004 | 05:07 PM
no it doesn't dim at all when i turn the headlights on, there was an extra wire for the dimmer but no wire to connect it to, john666 pm'd me and explained how to wire it to the fuse box... i thought about tinting it but then it'd be weird during the day
Old Sep 18, 2004 | 05:38 PM
Xsi's Avatar
Xsi
Yeah you need to connect that dimmer wire. I just connected mine to a light that happened to be near by on my DA, it doesn't need much current as it is just a small relay within the head unit.
Old Sep 18, 2004 | 05:48 PM
Eric R's Avatar
Default Re: (blackcivic44)
Dimmer wire and Illumination wire are not the same thing.
New radios use Illumination connection, not the dimmer one.
Old Sep 19, 2004 | 08:43 AM
GetawayInMoscow's Avatar
Default Re: (Eric's R)
I'm 99% sure the cheaper Panasonics can not be dimmed. The one I have in my Jeep however has a button under the volume **** that says DIM and I can push that and get it dark enough to not **** me off at night.
Old Sep 19, 2004 | 08:56 AM
Honda97's Avatar
Default Re: (GetawayinMoscow)
no it cannot be dimmed. take apart the headunit and just cut off the leds u do not want. i did that and it works just fine
Old Sep 19, 2004 | 03:30 PM
Default Re: (Honda97)
i definitely don't trust myself with taking apart the head unit
Old Sep 19, 2004 | 08:31 PM
Honda97's Avatar
its like 6 screws and jus kill da leds
Matth3w
Honda Civic (2006 - 2015)
16
May 29, 2013 10:51 AM
siR-E_978
Jul 27, 2009 04:55 PM
jers99
15
Oct 16, 2008 03:01 PM
mustang5.slow
Mar 18, 2007 09:49 AM
BLUE EH3
Nov 9, 2006 10:09 PM
