Replacing steering box
Old Sep 16, 2004 | 04:21 PM
TekSI's Avatar
Default Replacing steering box
I have a 92 si, and the power steering box is leaking. i used probably 1 bottle of Honda steering fluid in 3 weeks, then it stopped losing it. last weekend, when i turned all the way to the left, it would make a high pitch humm, sounded like a muffled horn, then as i straightened out, it would sound like metal scraping. did it 4 times, not anymore.
any ideas what the noises were, and how hard is it to install a new box?
i don't want to convert to manual steering, just wanna fix what i have
Old Sep 16, 2004 | 04:55 PM
chad's Avatar
Moderator
Default Re: Replacing steering box (TekSI)
gotta change the whole rack...this is a common problem with honda's
Old Sep 16, 2004 | 05:00 PM
TekSI's Avatar
Default Re: Replacing steering box (chad)
how hard is it to change the rack? i can grab one from a junkyard no problem, they have plenty there...i'm not expecting it to be an hour thing, i'm sure there's plenty involved
Old Sep 16, 2004 | 05:17 PM
chad's Avatar
Moderator
it's probably a 4-5 hour job...
Old Sep 16, 2004 | 06:07 PM
TriniTech's Avatar
it'll take a while, hope you got access to a lift. wheels off, disconnect tie rod ends, ps lines from rack. there's a bracket on the pass. side that you need to remove, disconnect the steering rack input shaft that goes into the car. this can be a bit of a pain, drop the subframe and lower the steering rack until the input shaft is out that about sums it up, like i said its not a amateur task, it'll help if you have a friend or 2 to help. haynes manual always handy. good luck.
benjaminenjamin
Suspension & Brakes
Nov 19, 2006 09:51 AM
brockscivic
11
Jun 1, 2005 06:20 AM
an2ny888
May 27, 2005 05:06 AM
4DRmafia
Feb 18, 2005 06:58 PM
