Stiff changing gears
might be your clutch buddy. clutch pedal will feel the same
you have to shove it into gear right?
you might start having problems where clutch pedal is all the way down, and your car stalls..
but might be many other things. its been discussed alot. searching would help.
make sure you have fluid in you reservoir. i had a similar problem on my 3rd gen. my guess is that if changing your tranny fluid did nothing it has to do with you master/slave cylinder it could be the clutch itself too like someone else said.
habanerored06si
Honda Civic (2006 - 2015)
Jun 15, 2013 02:12 AM
