How many pounds of boost can i push with an LS Vtec?
Old Sep 16, 2004 | 11:47 AM
ProjektCRX2's Avatar
Default How many pounds of boost can i push with an LS Vtec?
ok, here's pretty much my plan for my CRX project. I've decided to go LS vtec in my 91 crx Si. I kno i'll have to replace the rods and pistons. I was thinkin of goin with CP pistons and i havent decided which rods i should go with. Well the turbo that i'm gonna go with is the GT30R. I want to get as much power outta this motor. If u have any suggestions about anything i should do, please tell me...i need all the options to consider.
Old Sep 16, 2004 | 12:01 PM
tgreaves's Avatar
Default Re: How many pounds of boost can i push with an LS Vtec? (ProjektCRX2)
Figure out how much power you want to put out.. Then tune your car with the turbo to put out that amount of power.. I dont know how much boost that will be but it will vary from setup to setup..
Old Sep 16, 2004 | 12:08 PM
_entropy's Avatar
Default Re: How many pounds of boost can i push with an LS Vtec? (tgreaves)
How do you know you need to replace the pistons and rods? Lots of people are making 250-300 WHP on stock LS motors, what makes your case special? I am going to be installing my LS/VTEC setup with a T67 turbo in about 30 minutes here, should be fun. One of the things you should look into is new rod bolts, I've heard that the LS rod bolts have a tendancy of streching at higher RPM's.
Old Sep 16, 2004 | 12:19 PM
tgreaves's Avatar
Default Re: How many pounds of boost can i push with an LS Vtec? (@lbert)
Alot of that has to do with the tuning you have and what equipment you have around that.. Also some of it is luck..
Old Sep 16, 2004 | 12:29 PM
well i guess i dont know...but i'm puttin the rods and pistons cause i dont want 300whp i want more than that....im tryin to max out this motor. im jus tryin to gather up more info so i know exactlly what to do
DADADAAAMN
Mar 5, 2006 09:42 PM
silent-chris
Jun 30, 2005 12:39 PM
del_orson
Jun 7, 2005 07:13 PM
cornbread
Nov 7, 2001 09:15 AM
