i unplugged the 3-p connector from the ELD...
i unplugged the 3-p connector from the ELD and there was a whole bunch of grey goop on the metal conectors, it would start but after i disconnected it to check my voltage, then connected it again my car wont start now...
Needs to be About 20% Cooler
i've heard rumers that if a 5V sensor (MAP, TA, TW, TPS, ELD, all in dizzy, PA) gets a short in it it will blowout the 5V regulator chip in the ECU and the main prosesor inside has no power, causing no fuel and no start. u can try to solder in a new one or get a new ECU
hybridmath
30
Jul 20, 2008 03:38 PM
