Project Update: Stage 1
Old Sep 16, 2004 | 07:27 AM
97TegraLS's Avatar
Default Project Update: Stage 1
Here is the engine as I got it. The timing belt broke, and dealer said there were bent valves.
After taking off the valve cover I saw small drops of antifreeze in the oil. THe engine needed a head gasket, and maybe more.
Cylinder head shortly after pulling it from the block. NO BENT VALVES!!!
Carbon build-up on the combustion chambers
Cylinders shortly after pulling the head off. PISTONS LQQK GOOD!!
Cylinder wall
Cylinder head after I use oven cleaner to strip off oil and carbon. A toilet
brush is good to scrub with. I plan on painting the head flat black.
Clean values and chamber
Use the gasket as a templete to widen the exhaust ports
Piston after cleaning
Freashly painted intake manifold and components
Freashly painted valve cover
Gaskets are in, the block brace and turbo system should be in next week.
Modified by 97TegraLS at 10:36 AM 9/16/2004
Old Sep 16, 2004 | 07:41 AM
VTECorona's Avatar
Default Re: Project Update: Stage 1 (97TegraLS)
Learn to resize your pics you buttnut.
Old Sep 16, 2004 | 07:47 AM
iH8RICERZ's Avatar
Default Re: Project Update: Stage 1 (VTECorona)
HOLY CRAP!! DEFINATELY NOT 56k friendly. I'm on the schools t1 or somechit system and its still taking days to dl the pics! Please RESIZE!!!!
Old Sep 16, 2004 | 09:05 AM
Redtail's Avatar
Default Re: Project Update: Stage 1 (iH8RICERZ)
looks great to me dude. so are the valves bent or what?
Old Sep 16, 2004 | 09:14 AM
97TegraLS's Avatar
Default Re: Project Update: Stage 1 (Redtail)
The car was a coworkers that I got for $1000
He paid $230.00 to have the dealer installed a new timing belt. They said 35% compression in the #1 cylinder.
The cylinder head and pistons look fine. The low compression was from the head gasket
Old Sep 16, 2004 | 09:19 AM
skunkintegra's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97TegraLS &raquo;</TD></TR><TR><TD CLASS="quote">The car was a coworkers that I got for $1000
The cylinder head and pistons look fine. The low compression was from the head gasket </TD></TR></TABLE>
damnit.. why cant i ever find deals like this
for project b00st!
Old Sep 16, 2004 | 09:31 AM
kikwear002's Avatar
are u just leaving your head sit on concrete.... i would never do that..
Old Sep 16, 2004 | 09:39 AM
97TegraLS's Avatar
Default Re: (kikwear002)
That is asphalt, and of course none of the machine surfaces touch anything but cloth. There is nothing wrong with sitting a cylinder head on its side.
Old Sep 16, 2004 | 10:23 AM
iBear's Avatar
Default Re: (97TegraLS)
lookin good man
Old Sep 16, 2004 | 04:34 PM
97TegraLS's Avatar
Default Re: (EJellyfish1)
Thanks.
While I wait for the parts, I am going to remove the valves, clean the stems, and lap them to the seats. That is when I am going to blend the bowls on the exhuast side.
Old Sep 16, 2004 | 04:53 PM
LyL18's Avatar
Yeah, i would atleast put the head on some paper or something. Paint look snice though
Old Sep 16, 2004 | 05:19 PM
Cramerox's Avatar
Default Re: (LyL18)
hahaha what do you tell your coworker when he sees you driving around in the fixed car? damn 1k for a 3gen teg and only a bad hg and belt..nice deal.
DCRB
Mar 26, 2016 01:37 AM
brodyl05
Mar 12, 2007 09:56 PM
92TypeR
Nov 5, 2005 06:35 AM
crx1856
Sep 4, 2003 10:00 PM
Y2KGreenGSR
Nov 1, 2002 06:03 PM
