car wont rev past 6800
Old Sep 15, 2004 | 06:37 PM
99bb6's Avatar
Default car wont rev past 6800
my car: 99 5spd base
what could be wrong? i have a c.e.l for the secondary o2 sensor, but thats the only thing. what could be other factors that i cant rev passed 6800
Old Sep 15, 2004 | 06:41 PM
BlacktraxGirl's Avatar
Default Re: car wont rev past 6800 (99bb6)
your car has to be in safe mode for some reason. Maybe you have a soft code somewhere. Ive had the code61 for a long time and ive never gone into safe mode because of it. Try pulling the code again...sometimes its a ghost code. My car was in safe mode for almost 2 months before it would give up any codes. turned out to be the VSS.
Old Sep 15, 2004 | 06:53 PM
H1PNOT1C PRELUDE's Avatar
Default Re: car wont rev past 6800 (BlacktraxGirl)
does the vtec engage wenever its supposed to?....if it doesnt try the usual....check oil pressure....clean vtec solonoid....theres a whole page on it on the board somewhere, but if it is engaging then i dono
Old Sep 16, 2004 | 09:04 AM
breathinez's Avatar
Default Re: car wont rev past 6800 (H1PNOT1C PRELUDE)
I'm having prob. with mine also. At around 6800 the car feels like its cutting out. I'm going to change to a msd sci plus ignition and blaster 2 coil to see if that helps. I've gone through and changed plugs,rotor cap, button, wires, egr valve( had a cell for it), replaced second O2 sensor( had a cell for it, but I messed that up), I now have a cell for the number 1 O2 sensor. I also had the vtec solonoid cleaned. I'm blowing alot of soot latly which I understand all Preludes run rich. But I have 103,000 miles so maybe the carbon build up in my exhaust components like my cat have something to do with it, I don't know. If I ever get it fixed which I WILL DO someday I'll let you know.
Old Sep 16, 2004 | 11:10 AM
99bb6's Avatar
Default Re: car wont rev past 6800 (breathinez)
got my cel's checked out still the same ones, map sensor and secondary o2 sensor. ive noticed everytime i turned off my car it sounds like a frying pan like oil popping and stuff?? also there is alot of steam that comes out inbetween the intake manifold and block.
also can a bent vavle be causing this to happen???
Old Sep 16, 2004 | 12:06 PM
99bb6's Avatar
Old Sep 16, 2004 | 03:10 PM
BrokeLude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99bb6 &raquo;</TD></TR><TR><TD CLASS="quote"> ive noticed everytime i turned off my car it sounds like a frying pan like oil popping and stuff?? also there is alot of steam that comes out inbetween the intake manifold and block.
also can a bent vavle be causing this to happen???</TD></TR></TABLE>
One thing you've got is a water leak somewhere behind the engine, causing the noise and steam...
Old Sep 16, 2004 | 10:33 PM
99bb6's Avatar
Default Re: car wont rev past 6800 (BrokeLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrokeLude &raquo;</TD></TR><TR><TD CLASS="quote">
One thing you've got is a water leak somewhere behind the engine, causing the noise and steam...</TD></TR></TABLE>
i know it would cause the steam but how could it cause that noise?
Old Sep 17, 2004 | 06:49 AM
99bb6's Avatar
??? pulled codes again and still only secondary o2
Old Sep 17, 2004 | 07:02 AM
Pre1ude's Avatar
I had the same problem uin my lude it turned out to be the wire to the vtec solenoid was unplugged and i was still having the problem once in a while, so i took of the solenoid and cleaned the deris from the screen and checked the valve, NOT a problem since.
Old Sep 17, 2004 | 08:05 AM
prelude1897's Avatar
Default Re: car wont rev past 6800 (Pre1ude)
It could possibly be your crank shaft sensor that has gone out or maybe a wire burnt out on it....Awhile back with my other Prelude, it would rev past 4000rpms and it kept throwing a sensor code, come to find out, it was the crank shaft sensor. Its not that hard to replace, as long as you have air tools
Old Sep 17, 2004 | 12:44 PM
99bb6's Avatar
Default Re: car wont rev past 6800 (prelude1897)
i took off and cleaned the vtec solenoid, the problem still hasnt gone away. i didnt think it was the vtec solenoid in the first place b/c i didnt have a cell for it, but just thought id try. if a wire was cut or disconnected would i get a cel?
Modified by 99bb6 at 6:20 PM 9/17/2004
Old Sep 17, 2004 | 05:35 PM
bb6h22's Avatar
bumb b/c i cleaned my vtec solenoid today too maybe check the ecu?
91hatchproject
Mar 29, 2010 04:40 PM
PaImportTuner
Sep 21, 2005 10:41 AM
Timmay
Feb 4, 2004 02:34 PM
6SPD_EK
Feb 20, 2002 02:52 PM
