Hondata vs. safc
Old Sep 15, 2004 | 01:31 PM
harwood39's Avatar
Default Hondata vs. safc
is Hondata alot better tuning wise than an apexi safc? I would get a Hondata s200 unit if i get hondata.
Old Sep 15, 2004 | 01:35 PM
Street Ghost's Avatar
Default Re: Hondata vs. safc (harwood39)
I think so, but I'm biased because Im running Hondata.
screech's Avatar
well hondata is NOT A PIGGY BACK unlike safc which "tricks" your ecu plus the tuning capabilites are endless with hondata so yes hondata is better x 10^10
Old Sep 15, 2004 | 01:38 PM
harwood39's Avatar
Default Re: Hondata vs. safc (screech)
Ok, next question. Can i use hondata without dynotuning it?
Old Sep 15, 2004 | 01:40 PM
screech's Avatar
you can but whats the point, the reason your gettin the hondata is to tune it correct? if your gonna spend the money on it spend the money to get it dyno tuned
Ricey McRicerton's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by harwood39 &raquo;</TD></TR><TR><TD CLASS="quote">Ok, next question. Can i use hondata without dynotuning it?</TD></TR></TABLE>
No, but you should'nt be using an AFC without dyno time either.
Depending on your application an AFC may be better for you. It is less expensive, and unless you need the timing adjustments that are available with the Hondata and not the AFC, your wasting your money on the Hondata. Also, keep in mind you have to have a decent tuner in your area of your just screwing yourself in the end.
Old Sep 15, 2004 | 02:17 PM
WOPCIVIC's Avatar
Hondat is 10 X's better than a safc. On safc you add fuel it automatically takes away timing. Stupid design in my opinion. Just tune the hondata
Old Sep 15, 2004 | 02:39 PM
shamoo's Avatar
Will you make something up for me please?
First question....there is no comparison. Hondata is A LOT better than a lowly AFC.
Second questions....you can, but it would probably be worse than your stock ECU. You will have a base program, which most probably isn't tuned for your application. The reason to have a Hondata is to tune it. Just plugging it in your car won't really do anything. It could be the same, be worse, or be better. No one knows.
Old Sep 15, 2004 | 02:52 PM
blueballs90si's Avatar
Default Re: Hondata vs. safc (shamoo)
hondata is why better
Old Sep 15, 2004 | 03:33 PM
pane93civhb's Avatar
looking for opinions on both i do have both of these motors both in different cars and. was wondering how much of an improvement would each one be and what one will work better with which.. U no help me out if u have any info. or opinions or even if u wana burn me for asking about it.
Old Sep 15, 2004 | 03:35 PM
Default Re: Hondata vs. safc (pane93civhb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pane93civhb &raquo;</TD></TR><TR><TD CLASS="quote">looking for opinions on both i do have both of these motors both in different cars and. was wondering how much of an improvement would each one be and what one will work better with which.. U no help me out if u have any info. or opinions or even if u wana burn me for asking about it.
The improvements are going to depend on your tuner. If they're just a mostly stock motor, save your money and go with the AFCs. You don't really need the adjustability of the timing until you have SERIOUS upgrades on a N/A motor or a FI motor that is making a lot of power. Also, most tuners are much more comfortable with an AFC than Hondata.
Luserkid's Avatar
Uberdata + VAFC
Old Sep 15, 2004 | 04:22 PM
BLUE EH3's Avatar
Help we my pennies
prices?
Old Sep 15, 2004 | 05:31 PM
harwood39's Avatar
Default Re: Hondata vs. safc (BLUE EH3)
s-vafc is alot cheaper than hondata, i looked it up. Im just going to go with vafc for now, hodata is way way way out of my price range.
Old Sep 15, 2004 | 06:19 PM
specv5150's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by harwood39 &raquo;</TD></TR><TR><TD CLASS="quote">s-vafc is alot cheaper than hondata, i looked it up. Im just going to go with vafc for now, hodata is way way way out of my price range.</TD></TR></TABLE>
See keywords in that sentence is for now. Depending on your setup a AFC MAY be more beneficial/economical/etc BUT what are your end goals. Why pay $180-$300 for a new or used VAFC, to turn around and sell it later for maybe 60-75% of what you payed for it and turn around and buy a hondata. IF you can live without either, save up to get Hondata if it will eventually better suit your needs.
Old Sep 15, 2004 | 06:23 PM
Default Re: Hondata vs. safc (specv5150)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by specv5150 &raquo;</TD></TR><TR><TD CLASS="quote">
See keywords in that sentence is for now. Depending on your setup a AFC MAY be more beneficial/economical/etc BUT what are your end goals. Why pay $180-$300 for a new or used VAFC, to turn around and sell it later for maybe 60-75% of what you payed for it and turn around and buy a hondata. IF you can live without either, save up to get Hondata if it will eventually better suit your needs.</TD></TR></TABLE>
By that theory, I should have never bought a Civic. The REAL car I wanted was a Corvete, so I should just save for one, because I can't sell my Civic for what I payed for it.
An AFC will cover 90% of the people on this boards tuning needs just fine. No need to pay 400+ dollars for Hondata when it's overkill.
Old Sep 15, 2004 | 06:38 PM
specv5150's Avatar
Default Re: Hondata vs. safc (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">
An AFC will cover 90% of the people on this boards tuning needs just fine. No need to pay 400+ dollars for Hondata when it's overkill. </TD></TR></TABLE>
Well what I was saying was if he thinks he will eventually need a Hondata, why buy a VAFC first?? I dont know what his goals are and he may or may not outgrow the afc. if he may outgrow and can forsee himself buying a hondata, then buy the other product from the get go.
rustydusty1717
Engine Management and Tuning
59
Dec 15, 2008 05:00 PM
Accord6Gen
Sep 6, 2004 08:29 AM
mrod006
Feb 14, 2003 04:41 AM
