91 crx si map sensor
Old Sep 15, 2004 | 11:23 AM
atomazz's Avatar
Default 91 crx si map sensor
ok well i was trying to get into my wireing harness and i accidently cut two wires and later i find out the are for the map sensor, i spliced the wires back together and its throwing the code, i tried a new map sensor and still throwing the code i ran a new wire and its still throwing the code i am out of ideas and my car is dead, i tried switching ecus but i only had a old hf ecu and with my ls/vtec swap it wouldnt start, i am out of ideas and i need help if anyone can help me let me know, thanks
Old Sep 15, 2004 | 11:28 AM
spaceman's Avatar
Default Re: 91 crx si map sensor (atomazz)
did you connect the correct wires? can you take a picture of it?..try soldering it with electrical solder..
BigbamaBen
Oct 4, 2013 02:45 AM
mr2turbo007
Apr 23, 2012 06:22 PM
Groove_D
May 27, 2006 11:40 AM
89hb
Jan 6, 2003 06:11 AM
