gsr fuel pump good for greddy turbo kit?
I will be installing the greddy turbo kit on my gsr i will be up grading my fuel pump in a couple of weeks after but i have to get my hondata chip for base map first would it be ok to drive around using the gsr fuel pump?
i was wondering the same thing, im throwing a code for"system running to lean". ive checked everything 4 or 5 times now and its all hooked up right. im on the blue box which should be running alittle rich. anyone else what i might be if everthing is hooked up correctly?
stock pump can dish out a decent amount of power.
what whp are you shooting for? (anything above 300) i think it would be benifical in the long run to upgrage to walbro. Or else you would be shorting the life of the OEM pump.
mike2343
Feb 2, 2006 07:22 PM
boostincoupe
May 9, 2003 10:33 PM
