3rd grinds
Old Sep 15, 2004 | 09:22 AM
EFin' Kyle's Avatar
Default 3rd grinds
ok i just got my b16 swap done in my rex. at first the clutch pedal kept sticking in so i adjusted the clutch cable and that stopped teh sticking but now it grinds when i shirt into 3rd at high RPMs what is it? is it a bad syncro or do i need to adjus tthe clutch cable more? also it didnt do it b4 i adjusted the clucth cable.
-Kyle
Old Sep 15, 2004 | 09:25 AM
Reelizmpro's Avatar
Default Re: 3rd grinds (crxstreetracer90)
hmmmm so adjust it back! I hear 3rd gear grinds is quite common, however, mine doesn't do it. It seems to be a trait of B16A swaps.
Old Sep 15, 2004 | 09:27 AM
EL Vap133's Avatar
You have the same problem as this guy: https://honda-tech.com/zerothread?id=988890
This guy solved his problem: https://honda-tech.com/zerothread?id=522772
Old Sep 15, 2004 | 09:33 AM
Reelizmpro's Avatar
Default Re: 3rd grinds (EL Vap133)
Ahh that must be it. I have the front tranny mount on mine. Someone was saying that it's not needed but I guess it is if you don't want to grind going in 3rd!
Old Sep 15, 2004 | 09:37 AM
EFin' Kyle's Avatar
Default Re: 3rd grinds (Reelizmpro)
i have a rear mount tho. wont that help or no? also taht syncromesh stuff what is that. sry if thats a dumb question i dont know a whol lot on trannys.
-kyle
Old Sep 15, 2004 | 10:03 AM
ooairewreckoo's Avatar
syncomesh is just tranny oil. in some cases it solves slight grinds but now always. Its worth a shot its only 10$ a quart i believe.
Old Sep 15, 2004 | 10:10 AM
LSVTEC 91 Civic's Avatar
Banned
Default Re: 3rd grinds (ooairewreckoo)
Synchromesh
Old Sep 15, 2004 | 10:32 AM
crx_88_si's Avatar
lol... lets see.
"alot of b16 swaps have 3rd gear grinds"
now how many of those are using a pre made mount kit like hasport or hcp.
installing a good front mount fixed the 3rd gear grind..
do i see a possible pattern?
Old Sep 15, 2004 | 10:37 AM
kim_2_da_chee's Avatar
Default Re: 3rd grinds (crx_88_si)
i have a pre-made mount kit from AZ Mach.Desn., and i use syncromesh. No grinds here
Old Sep 15, 2004 | 01:04 PM
Yellb16crxsi's Avatar
Default Re: 3rd grinds (kim_2_da_chee)
syncromesh try it it stopped my tranny from grindin
i dont see how the front mount will change anything
Old Sep 15, 2004 | 01:33 PM
mellon's Avatar
Default Re: 3rd grinds (Yellb16crxsi)
I have the third gear grind, but I'm still running on my stock a6. Going to try the syncromesh, hopefully that'll help.
Old Sep 15, 2004 | 01:39 PM
520_Motorsports's Avatar
Mine grinds in fourth gear only and only on qouck shifts, if I hokld the clutch in for a sec it does not do it. <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Yellb16crxsi &raquo;</TD></TR><TR><TD CLASS="quote">syncromesh try it it stopped my tranny from grindin
i dont see how the front mount will change anything</TD></TR></TABLE>
We put GM Synchromesh in my friends civic and it stopped the grinding in his h22 hatch. Give it a try.
felipe69
Mar 19, 2009 11:14 AM
AutoLab
Aug 28, 2005 09:48 AM
srv3fender
Mar 24, 2005 07:16 AM
srv3fender
10
Mar 24, 2005 05:28 AM
senpai
Apr 30, 2002 01:15 PM
