Skunk2 stage 2 with CTR pistons in B18C1 block with PR3 head???
Old Sep 15, 2004 | 09:04 AM
95dc2's Avatar
Default Skunk2 stage 2 with CTR pistons in B18C1 block with PR3 head???
will it hit??? i've found several threads asking similar questions regaurding same cam/piston setup, but varied blocks and heads. i've been searching all day. anyone know? TIA
Old Sep 15, 2004 | 09:27 AM
Civichatch2k's Avatar
Default Re: Skunk2 stage 2 with CTR pistons in B18C1 block with PR3 head??? (95dc2)
If you are putting this motor together then I would clay the motor to make sure that the vale/pistons do not hit.
CTR pistons are fairly high domed, clay it and be sure.
Old Sep 15, 2004 | 10:24 AM
95dc2's Avatar
Default Re: Skunk2 stage 2 with CTR pistons in B18C1 block with PR3 head??? (Civichatch2k)
i'm no expert on this, but i assume that since i have dumped my gs-r head (now have pr3 head), that i pretty much have a similar set-up to an itr....i have read where many of them (B18C5) have gone to CTR pistons and cams with no issue....clay is the safest bet as always. just trying to geta feel before i go to the machine shop.
Old Sep 15, 2004 | 10:53 AM
Combustion Contraption's Avatar
Im sure this setup has been run before. try searching (not meant to be offensive)
Old Sep 15, 2004 | 10:56 AM
95dc2's Avatar
Default Re: (LsVtec92Hatch)
no offense taken, i have searched. i'll try some more. search can be a little picky
Old Sep 15, 2004 | 11:33 AM
radeon's Avatar
you will be fine. i did the same set up on my c5 block ctr pistons and sk2 st2 cams and never had a problem.. untill i spun a rod bearing the c5,c1,18a/b are the same , just the parts in side are diffent....good luck ,,, and use honda bearings there the best ...
Old Sep 15, 2004 | 11:38 AM
95dc2's Avatar
Default Re: Skunk2 stage 2 with CTR pistons in B18C1 block with PR3 head??? (radeon)
thank you i've been looking all over for the answer for this today. unfornately i have to return to the machine shop, so i figured i'd swap pistons while i was there. CR should be around 12:1 or a little more, right?
do you know if i have room to mill head? (just getting greedy)
Old Sep 15, 2004 | 11:43 AM
radeon's Avatar
i would leave the head not milled .. milling it could have the pistons not clear
Old Sep 15, 2004 | 11:55 AM
95dc2's Avatar
cool deal, according to the two compression calculators i have found, my CR should be good enough for the stage 2's. thanks again for your info...tg
wil-DC2
Apr 11, 2015 09:03 PM
Man_EK9
Feb 10, 2008 11:52 AM
ALLMOTOR CRX
18
Jun 22, 2007 01:39 AM
b18c-rDC2
Mar 12, 2003 01:27 PM
Skunk2_92gsr
Dec 18, 2002 07:54 PM
