damn!!! upper bolt hole on tranny cracked? how bad is this?
Old Sep 14, 2004 | 09:58 PM
stockegsix's Avatar
Default damn!!! upper bolt hole on tranny cracked? how bad is this?
Modified by stockegsix at 10:33 PM 10/17/2004
Old Sep 14, 2004 | 10:14 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: damn!!! upper bolt hole on tranny cracked? how bad is this? (stockegsix)
i wouldnt sweat it too too much but keep a eye on iot...dont know about welding th etranny casing...maybe it would work who knows....
Old Sep 14, 2004 | 10:34 PM
showtymers619's Avatar
* B A N N E D *
Default Re: damn!!! upper bolt hole on tranny cracked? how bad is this? (SnoFlake EG)
weld fill the whole not too much just enough to close up the crack.. and retap it.. done it b4
Old Sep 14, 2004 | 10:58 PM
stockegsix's Avatar
Default Re: damn!!! upper bolt hole on tranny cracked? how bad is this? (ShowTymers619)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ShowTymers619 &raquo;</TD></TR><TR><TD CLASS="quote">weld fill the whole not too much just enough to close up the crack.. and retap it.. done it b4</TD></TR></TABLE>
many many thanks, although, Ive been thinking about this all day since i cracked it. Im glad someone has done it. thank you again sir!
Old Sep 15, 2004 | 01:11 AM
dantastic's Avatar
i would try to find a busted tranny and use it to replace the case
Old Sep 15, 2004 | 02:01 AM
TurboEH2's Avatar
Default Re: (dantastic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dantastic &raquo;</TD></TR><TR><TD CLASS="quote">i would try to find a busted tranny and use it to replace the case</TD></TR></TABLE>
id do that. unless u know someone who can weld aluminum, then id go for the fill it with weld then drill and tap it. there was a thread about this not to long ago and alot of people had great suggestions of what to do and they had pictures of it.
Old Sep 15, 2004 | 08:46 AM
stockegsix's Avatar
Default Re: (LSturboEH2)
thanks, anyone else?
Old Sep 15, 2004 | 08:57 AM
JDMFreak's Avatar
Default Re: (stockegsix)
make sure you get it done asap, for example i could never figure out why my 2nd and 5th gear always act funny/slip out of gear from time to time...when i did my motor swap i notice that one of the bolt on the tranny was gone/broken....so i think 2 out of the 3 bolts will not hold the tranny good/strong and it could possible grind the gears over time?....
Old Sep 15, 2004 | 10:05 AM
lilbastrd's Avatar
Default Re:
haha i knew it had to be you that post this when i saw the topic, good luck on it
Old Sep 15, 2004 | 03:53 PM
stockegsix's Avatar
Default Re: (JDMFreak)
TTT
Old Sep 15, 2004 | 05:09 PM
Andres-eh2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSturboEH2 &raquo;</TD></TR><TR><TD CLASS="quote">
there was a thread about this not to long ago and alot of people had great suggestions of what to do and they had pictures of it.</TD></TR></TABLE>
Might be talking about my thread.
https://honda-tech.com/zerothread?id=943834
Old Sep 15, 2004 | 06:47 PM
stockegsix's Avatar
thanks
Old Sep 16, 2004 | 07:48 AM
authentic plusONErandy's Avatar
if youre going to just run two bolts on it for now, find a bolt that can "plug" the other hole... because if u peak in the hole u can see the gears... u dont want dirt in there
i been running with 2 bolts and its still fine.... but theres a lot of stress marks that develop on the tranny over time.
Old Sep 16, 2004 | 07:57 AM
dohcdelsol93's Avatar
Default Re: (usdm toilet)
My tranny (91 ls cable) has been running with only 2 holes for a while with a perfomance clutch, no probs yet. Mine is missing top tranny bolt, i see no gears though just a chunk of missing housing, it enough to make you wanna spit though. I need a gsr tranny anyway. I'm going to run it til it dies. if the other bottom hole gives, as long as it's not bad, I could still limp home with a very animated engine and tranny.
Old Sep 16, 2004 | 09:51 AM
stockegsix's Avatar
I dont think that the hole goes through, I dont see the inside of the tranny through the hole. Im just gonna get this hole welded shut
Old Sep 16, 2004 | 07:34 PM
maybe we're talkin bout different holes
Old Sep 16, 2004 | 08:17 PM
stockegsix's Avatar
thanks for the replies. pics are now up
Thefbomb13
Honda Civic (2001 - 2005)
Jun 5, 2008 07:38 AM
Pete_SI
18
Jul 28, 2005 05:47 AM
SoOHiGH
May 4, 2005 02:13 PM
EFHbSi
Apr 30, 2005 07:50 PM
CRX-RX
10
Mar 23, 2004 01:36 PM
