can i turn up my boost??
Old Sep 14, 2004 | 08:26 PM
_SHEP_'s Avatar
Default can i turn up my boost??
First off i have a b16a with stock everything other than exhaust. I was told that if i get some 116 oct. i could turn my boost up to like 9 or 10. Can I?
Old Sep 14, 2004 | 09:00 PM
Boltz's Avatar
Default Re: can i turn up my boost?? (BOOSTEDebp)
So if everything is stock, and you dont have a turbo or a supercharger. How are you planning on "raising" your boost?
Old Sep 14, 2004 | 09:03 PM
beepy's Avatar
Default Re: can i turn up my boost?? (Boltz)
Duh, with the flux capacitor.
Old Sep 14, 2004 | 09:30 PM
donkiman's Avatar
u dont need 116 octane to turn your boost up to 9 or 10 psi. you need a good ems and a good tuner. i run 9 psi on stock block all day long. (with hondata and a good tune)
Old Sep 14, 2004 | 09:39 PM
SOHC_MShue's Avatar
what engine managment do you have?
Old Sep 14, 2004 | 09:56 PM
plusONE jboy's Avatar
with proper engine management, and dyno tuning. yes.
Old Sep 22, 2004 | 08:56 PM
_SHEP_'s Avatar
Default Re: (j boy)
I just have an fmu right now. im not planning on leaving the boost at 9 or 10 but i wanted to try it out after someone mentioned it to me.
And sorry Boltz I forgot to mention that i have a garrett t3/t04 e turbo, i thought you would be able to put 1 and 1 together.
Old Sep 22, 2004 | 09:13 PM
.::Lee::.'s Avatar
Theoretically you could run 30 psi with 116 and a small turbo like that with proper fuel management (An FMU sure as hell is not proper management). As long as you didn't detonate, even a little, you'd be OK, you would just speed up the deterioration of your motor (probably 100 fold)
A good friend of mine ran over 20 psi. repeatedly this summer using 116 on a completely stock LS motor (read: original headgasket, head has never been removed) and ran 12.2's without even a hint of trouble (minus several broken axles). After we ran compression and leak down test, we found everything to be in top notch shape. This car was tuned to 250 hp by Cortney Green on pump gas, so it goes to show you, that it's all about precise tuning.
Old Sep 22, 2004 | 09:18 PM
turbolsintegra26's Avatar
Default Re: can i turn up my boost?? (Ibiza)
Actually Lee I was running 112 octane..... But its cool
Old Sep 22, 2004 | 09:22 PM
Default Re: can i turn up my boost?? (Turbointegra22)
Oh and just for the record I street tuned the map up to 20 PSI, & my a/f is 11.2:1 and i'm at 17deg adv. @ 20psi and cold plugs, results less than 10 % leakage, and 180 psi compression give or take 5 psi all the way across.
Old Sep 22, 2004 | 09:33 PM
.::Lee::.'s Avatar
who asked you?
Old Sep 23, 2004 | 08:05 AM
mdpalmer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ibiza &raquo;</TD></TR><TR><TD CLASS="quote">Theoretically you could run 30 psi with 116 and a small turbo like that with proper fuel management (An FMU sure as hell is not proper management). As long as you didn't detonate, even a little, you'd be OK, you would just speed up the deterioration of your motor (probably 100 fold)
A good friend of mine ran over 20 psi. repeatedly this summer using 116 on a completely stock LS motor (read: original headgasket, head has never been removed) and ran 12.2's without even a hint of trouble (minus several broken axles). After we ran compression and leak down test, we found everything to be in top notch shape. This car was tuned to 250 hp by Cortney Green on pump gas, so it goes to show you, that it's all about precise tuning.</TD></TR></TABLE>
Slight thread jack: what turbo was on the car? did you guys get dyno numbers for 20 psi of boost? sounds like a fun car!
Old Sep 23, 2004 | 08:50 AM
Default Re: can i turn up my boost?? (mdpalmer)
A small t3/t4 54 trim .63 a/r, not a lot of air volume. Its a fun car because no one believes its a completely stock motor, all I have beside the turbo & good tuning is a ACT clutch, Slicks, & and an exhaust. other than that stock everything.
Old Sep 23, 2004 | 10:17 AM
Zakar's Avatar
So yes and no.... you can run more boost with proper tuning and what not... but no you can't just turn it up..
Old Sep 23, 2004 | 05:36 PM
Default Re: can i turn up my boost?? (MusclecarGuyhasHonda)
Well you can, but you'll be pick up pieces of your motor off the ground, besides, turning up your boost without proper tuning and enough fuel won't make much or anymore power. I think this is done now, I'll shut up.
Old Sep 24, 2004 | 07:08 AM
Boltz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BOOSTEDebp &raquo;</TD></TR><TR><TD CLASS="quote">First off i have a b16a with stock everything other than exhaust. I was told that if i get some 116 oct. i could turn my boost up to like 9 or 10. Can I?</TD></TR></TABLE>
Im not sure how farmiliar you are with the FMU but what it does is as follows
lets say you have 38 psi of fuel pressure at idle
with a stock 1:1 regulator and 10 pounds of boost you would be at 48 psi of fuel pressure which is ok.
Now compare that to an FMU, which is a 12:1 regulator. 38 base fuel pressure + (10psi x 12) = 158 psi of fuel pressure, which is unreliable. This could overheat your injectors and lead them to fail.
You could probably do it a couple times and get away with it, but I think the major issues you'll run into is 1, way too much fuel pressure 2, way too rich because of the extra pressre in the rail.
If you got hondata and tuned it properly, you could boost 10 pounds a lot safer than you ever could with an FMU
Old Sep 27, 2004 | 07:51 PM
_SHEP_'s Avatar
Ok thanks for the input. I appreciate.
Old Sep 27, 2004 | 08:17 PM
FredoSP's Avatar
Default Re: (BOOSTEDebp)
180psi .. seems a tad low for a STOCK B16, don't you think? As long as they are very close to each other then
Nisif
Feb 11, 2006 12:35 PM
justinb
Jun 25, 2005 04:40 PM
electric_rex
Sep 24, 2004 06:21 AM
VeilSide_Mas
Jan 15, 2003 06:26 PM
tygsr
Jun 19, 2002 01:27 PM
