brake pad question
Old Sep 14, 2004 | 06:32 PM
wanna b R's Avatar
Default brake pad question
i just install brake pads on my car (front two)......after that my pad rub against my rotor and keep slowing my car down....and i took them off and install it again same thing...what can it be? the pads? i install brake pads b4 with no problem....
94 integra 2dr
Thanks for any info
Old Sep 14, 2004 | 06:45 PM
VTECrazed's Avatar
Default Re: brake pad question (wanna b R)
well sounds like the caliper piston when its pushing the pad against the rotor its not retracting and so its holding it against the rotor. Maybe time for new calipers.
Old Sep 14, 2004 | 07:14 PM
sabotage7's Avatar
are you sure you pushed the piston in all the way? sounds like its stuck or something?
Old Sep 14, 2004 | 08:40 PM
dohcroc's Avatar
Default Re: brake pad question (sabotage7)
try the caliber bins take them out clean them and grease them dont think its a bad caliber they dont go bad unless u have a really old car. keep us epdated cuz i had the same pro and this is wat i did and worked. good luck
GrayT's Avatar
When I was changing out my pads my front 2 pistons came out. After I got the pistons back in, only the front 2 pads were slowing my car down.
I just went out and broke them in. Brake until you're almost completely stopped then let off, you should smell the brakes and maybe it will help to get them settled in right.
This worked for me. If you need the exact procedure let me know.
Old Sep 15, 2004 | 07:01 PM
wanna b R's Avatar
Default Re: brake pad question (GrayT)
Thanks for the info guys i'll try it out this week and let u guys know
Old Sep 15, 2004 | 08:13 PM
chrisnova's Avatar
Well, if the problem just developed after changing the pads it is more likely that the pads just need breaking in. It could be too that the slides need lubrication too. You could apply some grease to them. Like someone else mentioned, it could be a sticky or partial siezed caliper if you perhaps compressed it at a bad angle to get the new pads on the front. On the rears be careful to adjust the piston so it isn't too close to the rotor or it will rub. The problem is the adjustment can only be made in 1/4 turn increments by rotating the the piston caliper.
turbo-crx
Jan 19, 2009 03:32 PM
dr_spock
Honda Civic (2001 - 2005)
Sep 20, 2008 10:22 PM
garrettej8
Mar 31, 2007 10:16 PM
athoughts
Nov 17, 2005 03:12 PM
tylerdurden
Jan 8, 2003 12:46 PM
