Ls/vtec with jackson racing super charger?
thinking about putting on a jackson racing supercharger on my ls/vtec stock block (other than arp rod bolts) with a portflow gsr head, 01 itr cams, 10:1 compression, jackson racing kit for a gsr, hondata of course, rc 440cc injectors & 11 psi of boost
just wanting to see if any one has a set up like this and what power there making
thanks
Modified by turbodav at 6:02 AM 9/20/2004
thanks
My GSR with stock innards, 3inch intake, DC 421 header, Hondata + RC440s, RSR catback made 251Hp/181lb-ft at the wheels at 10psi, just for reference...
Doug at Hondata found that the intake was worth 15Hp vs. the stock rubber tube/airbox I was using. I'm now using the Ghetto IceRam and it works fine for me...
i got similar setup but have not dropped in the motor yet... u might want to use arp rod bolts and block girdle on the bottom block... and i think u would want to use the gsr cams instead since they are more appropriate for the gsr head....
eg customs
Sep 25, 2008 08:01 PM
