hasport mount question?
Old Sep 14, 2004 | 03:02 PM
Agent Zero's Avatar
Default hasport mount question?
I have a question for all the ppl who have hasport mounts. I have just put in my mounts and wow. My dash raddles and especailly my sunroof. I stood outside the car (at idle) and I can hear just about everthing raddeling.(liscence plate, rear hatch, etc, etc) Is this normal? TIA
Old Sep 14, 2004 | 07:43 PM
gabhatch's Avatar
Default Re: hasport mount question? (redsihatchback)
mine does it to i hope its normal
the mounts are just super stiff
Old Sep 15, 2004 | 07:26 PM
brian g's Avatar
There are a couple of things here. Some of our shops order the mounts in the stiffer urethane. There are three stiffnesses available. Also cold mount vibrate more than warm ones this is natural with urethane. When you first start your car it will vibrate more than it will after it's been running 15 minutes. There is a little break in period depending on how you drive you car, figure 10 to 25 hrs of operation.
Vibration is also a function of the engine tune. A well tuned engine with the idle set to Honda's spec will vibrate considerably less. Even an idle set 100 rpm too fast can be harsh.
brian g
hondaman211
Jul 10, 2017 09:51 AM
Rob97'SH
Jun 9, 2012 06:22 PM
PowerLeg
Nov 6, 2008 10:16 PM
spiffy
Oct 11, 2005 08:35 PM
White HB
May 15, 2003 05:47 PM
