Oxy Acetylene welding..Good for exhaust/charge pipe work? Manifolds??
Old Sep 14, 2004 | 12:24 PM
ILLICON3000's Avatar
Default Oxy Acetylene welding..Good for exhaust/charge pipe work? Manifolds??
Ok well my neighbors got an oxy acetylene torch laying in his garage it's just taking up space. I was talking to him and he's only asking 65 bucks for it. It sounded like a good deal and I'm thinking about picking it up.. I know you can do brazing/heavy soldering with one..It's possible to use one for exhaust work and for charge piping too? I'm guessing it's not adequate for manifold work though? I've been researching welding ALOT but have zero hands on experience with it. (Well maybe in 8th grade shop class 6 years ago)..
Sound like a good deal? I think the tanks are filled.. Anyone have input?
Old Sep 14, 2004 | 12:42 PM
pb16b's Avatar
Default Re: Oxy Acetylene welding..Good for exhaust/charge pipe work? Manifolds?? (ILLICON3000)
torch with full tanks $65 bucks is a good deal... even if you don't use it for welding. you can do everything with oxyacetylene. it just won't turn out as pretty and as strong as mig or tig.
if you're a low budget do-it-yourselfer, oxyacetylene is cool.
Old Sep 14, 2004 | 12:47 PM
zer0bot's Avatar
Default Re: Oxy Acetylene welding..Good for exhaust/charge pipe work? Manifolds?? (pb16b)
What temp will ac/ox withstand and how much weaker is it?
Old Sep 14, 2004 | 02:33 PM
eLUDEnu
Guest
Posts: n/a
Default Re: Oxy Acetylene welding..Good for exhaust/charge pipe work? Manifolds?? (zer0bot)
I am a hvac service tech and I have those torches. But what would I use to weld with? Welding rods?
Old Sep 14, 2004 | 04:18 PM
SJcivic's Avatar
I wouldnt trust brazing to anything that physically needs to be strong, or that has some fuction with heat. A&O is good for cutting metal and making metal maluable... thats about it.
Welcome to TIG
Rich
Old Sep 14, 2004 | 04:27 PM
eLUDEnu
Guest
Posts: n/a
Default Re: Oxy Acetylene welding..Good for exhaust/charge pipe work? Manifolds?? (SJcivic)
[QUOTE=SJcivic]I wouldnt trust brazing to anything that physically needs to be strong, or that has some fuction with heat. A&O is good for cutting metal and making metal maluable... thats about it.
Welcome to TIG
Thats what I (thunk) but they were asking so I figured I would to
Old Sep 14, 2004 | 04:57 PM
pete98m3's Avatar
"I wouldnt trust brazing to anything that physically needs to be strong"
actually, brazing is quite strong. A lot of brazements have a higher tensile strength then the base metal, so for mild steel or whatever its just fine (not for high temp though). I've seen a car transporter with the 2nd level car racks (inside a semi truck type for race team) all brazed.
Old Sep 14, 2004 | 10:03 PM
b18cls1's Avatar
Default Re: (pete98m3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pete98m3 &raquo;</TD></TR><TR><TD CLASS="quote">"I wouldnt trust brazing to anything that physically needs to be strong"
actually, brazing is quite strong. A lot of brazements have a higher tensile strength then the base metal, so for mild steel or whatever its just fine (not for high temp though). I've seen a car transporter with the 2nd level car racks (inside a semi truck type for race team) all brazed. </TD></TR></TABLE>
oxy / gas welding is not bad at all and for someone who can gas weld when it comes time to tig it will be so easy you can gas weld just about anything like exhaust chargepipes ect and when you get good at it it will look like tig welds
Old Sep 15, 2004 | 08:35 AM
eLUDEnu
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18cls1 &raquo;</TD></TR><TR><TD CLASS="quote">
oxy / gas welding is not bad at all and for someone who can gas weld when it comes time to tig it will be so easy you can gas weld just about anything like exhaust chargepipes ect and when you get good at it it will look like tig welds </TD></TR></TABLE>
So are you saying it is the same techniqe as Tig welding? Cause im pretty damn good at brazing silver soder. once every 10-15 times i will find a leak. So what will i need to use to weld with my A&O torches? Welding rods?
Old Sep 15, 2004 | 09:04 AM
TurboJesse
Guest
Posts: n/a
Default Re: (b18cls1)
Im taking a gas course @ a local welding school. taking the course as a prelude to A comprehensive TIG course. Im doing 45 hours of oxy acetylene welding before i move onto tig..Im about 20 hours into the course and can lay some beads that my friends though were tig welds . A few of the pieces i welded together really came out nice looking. I can't wait to move onto tig (never touched a tig welder before ). Should it be alot easier to pickup now that im able to gas weld easily?
Old Sep 15, 2004 | 09:07 AM
eLUDEnu
Guest
Posts: n/a
Default Re: (Mpir3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mpir3 &raquo;</TD></TR><TR><TD CLASS="quote">
Im taking a gas course @ a local welding school. taking the course as a prelude to A comprehensive TIG course. Im doing 45 hours of oxy acetylene welding before i move onto tig..Im about 20 hours into the course and can lay some beads that my friends though were tig welds . A few of the pieces i welded together really came out nice looking. I can't wait to move onto tig (never touched a tig welder before ). Should it be alot easier to pickup now that im able to gas weld easily?</TD></TR></TABLE>
Well maybe you can answer my question. What do I use to weld with?
Old Sep 15, 2004 | 03:09 PM
SJcivic's Avatar
Default Re: (eLUDEnu)
A&O and TIG have some similair processes and ways to manipulate, but arent "if you can do one, than you can do the other"... but they're related.
Brazing having high tensil strength can only go so far. Tubular steel has higher tinsel strength than solid steel stock... but the tube will crush when a peice of stock will bend. (just making a point)
Brazing should (in my opinion) left as a last ditch fix until a prper weld can be done.
Brazing isnt physically bonding the two metals together, its a "glue" so to speak. With MIG, TIG, etc, you're getting the two to fuse together.
Rich
Old Sep 15, 2004 | 07:40 PM
eastbay92cx's Avatar
Default Re: (SJcivic)
I don't know the name of the thread, I think it's the old welding thread from the tech forum, there's some pics of some good gas welding. Oxyacetylene welding is perfectly strong and capable imo, just not maybe as fast or as easy as using a mig for example. If you're good with the torch and you can get both metals you're joining and the rod all liquid real nice like, don't worry about anyone saying it won't hold up to the heat, isn't strong enough, etc...
You need anything that will work as a filler rod (the same or higher grade metal) and maybe a different tip / torch if you only have a cutting torch. Good luck
Old Sep 15, 2004 | 07:50 PM
TurboJesse
Guest
Posts: n/a
Default Re: (eastbay92cx)
any input on this weld? it was a vertical butt weld ( sorry for shitty quality pic)
Old Sep 16, 2004 | 01:38 AM
L-CON1's Avatar
dont do it.
NipTucked
Welding / Fabrication
11
Apr 11, 2009 08:20 AM
getnasty
Sep 20, 2005 10:03 PM
1SlowSi
Mar 28, 2005 01:55 PM
MeanGreenEG9
Feb 25, 2003 01:38 PM
randomwalk101
Jun 19, 2001 12:30 PM
