Raising Compression w/o Cams or timing?
Old Sep 14, 2004 | 09:42 AM
Nolan's Avatar
Default Raising Compression w/o Cams or timing?
In HC non-hybrid you are allowed to raise compression by .5:1, but you are not allowed to change cams or cam timing. Is it worth it to raise the compression in the H22A1 w/o changing cams? The answer to raising compression in the H22A1 is best solved by head work, head gasket or pistons? I apologize for my ignorance with the H series engines
Old Sep 14, 2004 | 09:50 AM
98TypeSH's Avatar
Default Re: Raising Compression w/o Cams or timing? (Nolan)
head gasket, pistons, valves, and mill the head if your a nutbag.
Old Sep 15, 2004 | 04:18 AM
Nolan's Avatar
Default Re: Raising Compression w/o Cams or timing? (98TypeSH)
valves, you mean the combustion chamber or the actual valves?
Old Sep 15, 2004 | 05:29 AM
tuan...'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nolan &raquo;</TD></TR><TR><TD CLASS="quote">valves, you mean the combustion chamber or the actual valves?</TD></TR></TABLE>
he means gettin high comp valves and milling ur head
importfan2
19
Oct 21, 2008 06:18 PM
ddenson
Jul 31, 2007 12:06 PM
da.nizzle
May 1, 2007 08:16 PM
xDicktonesx
12
Mar 8, 2006 04:29 PM
luckypon7
Jan 5, 2004 09:48 PM
