Absolutely NO compression, Headgasket on upside down???
Old May 1, 2007 | 07:18 PM
da.nizzle's Avatar
Default Absolutely NO compression, Headgasket on upside down???
Well im taking the head to a machine shop b/c I assumed some valves were bent since it had no compression. When I took the head off today the headgasket looked a bit odd, so i flipped it over and it fit better. Could an upside down headgasket cause NO compression I mean none, it didn't even hit 20psi on ANY cylinders.
Also the valves dont completely shut with the head off and the cams set to tdc on cylinder 1. they look about 3mm open. bent valve?
Old May 1, 2007 | 07:20 PM
Legion's Avatar
* B A N N E D *
Default Re: Absolutely NO compression, Headgasket on upside down??? (da.nizzle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by da.nizzle &raquo;</TD></TR><TR><TD CLASS="quote">the valves dont completely shut with the head off and the cams set to tdc on cylinder 1. they look about 3mm open. </TD></TR></TABLE>
Are the rockers adjusted correctly?
Old May 1, 2007 | 07:23 PM
da.nizzle's Avatar
Default Re: Absolutely NO compression, Headgasket on upside down??? (Semtec)
good question. that could cause the valves to stick out more huh...ill try that now
Old May 1, 2007 | 07:50 PM
Legion's Avatar
* B A N N E D *
Well, if the rockers are physically touching the valvestems... it's going to keep the valves from closing. The rockers shouldn't be tight at TDC - they should wiggle up and down a little bit.
Old May 1, 2007 | 08:16 PM
da.nizzle's Avatar
the valve lash is WAY outta wack. the valves that i thought were bent aren't. i messed around with them and got them to shut completely. so i'm going to adjust them to spec and get a new headgasket and i should be good. also found out that the headgasket was indeed upside down.
B18C5_VTEC
Oct 8, 2007 02:54 PM
Nolan
Sep 15, 2004 05:29 AM
slowazzhatch
13
Jun 1, 2004 08:51 AM
NeVeR bLoWn
Oct 20, 2003 02:29 PM
