Wilwood 13in. Brakes
Old Sep 14, 2004 | 06:41 AM
billyhoe's Avatar
Default Wilwood 13in. Brakes
im about to change the pads out and figure i might as well change out the brake fluid also. Any suggestions? also does the anti squeal cream works on the polymatrix brake pads also, i was wondering because the back of the pads are all metal and didnt know if i should apply the cream on the pads
Old Sep 14, 2004 | 06:50 AM
rastropovitch
Guest
Posts: n/a
Default Re: Wilwood 13in. Brakes (billyhoe)
No it does not work, the polymatrix pads and the stainless steel pistons will always have some vibration to them. you can try a different compound than the D that they sell with the kit. I have used ferrodo's with great results, but the pads are very agressive. Try the j compound
Old Sep 14, 2004 | 05:14 PM
billyhoe's Avatar
Default Re: Wilwood 13in. Brakes (MSchu)
any other tips on installing brake pads such as what you use to push the pistons back in the bore, just anything you can think of that would make the installation process a smooth one, this the first time im changin the pads
Old Sep 14, 2004 | 05:16 PM
gsrboi80's Avatar
I would think a c clamp would compress the piston
Old Sep 14, 2004 | 09:48 PM
billyhoe's Avatar
Default Re: Wilwood 13in. Brakes (gsrboi80)
i was hoping for an easier way
Old Sep 14, 2004 | 10:54 PM
SMZ GSR's Avatar
Uhh, a C clamp is pretty damn easy if you ask me
BTW: what wheels are you using with your wilwood kit?
Old Sep 14, 2004 | 11:03 PM
Sack Master's Avatar
Default Re: Wilwood 13in. Brakes (SMZ GSR)
Just make sure to pinch off your brake lines if the fluid is old. You don't want that old crystalized burnt fluid bleeding up into your master cylinder.
Old Sep 15, 2004 | 10:58 AM
rastropovitch
Guest
Posts: n/a
Default Re: Wilwood 13in. Brakes (Sack Master)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by billyhoe &raquo;</TD></TR><TR><TD CLASS="quote">any other tips on installing brake pads such as what you use to push the pistons back in the bore, just anything you can think of that would make the installation process a smooth one, this the first time im changin the pads</TD></TR></TABLE>
Sure no problem, I have been running this set-up ever since it was first introduced. Been years now. I use a C clamp to push the pistons back into the caliper, But do not use the clamp on the piston, use the old brake pad/backing plate as a flat surface to which you push against with the c clamp. Also, use a Q-tip and clean teh exposed piston surface(along the sides of the exposed piston) to remove any dirt or grimme before pushing back into the caliper. You can do a quick bleed again after everything is push back and new pads are in... but it is not necessary. I use russel speed bleeders on my caliper top sides so I can do this all my self in about 5 minutes per side. also get a rebuild kit to have on hand, they are very cheap(about $15) and its good to have if you need to rebuild. some spare cotter pins are good to have to. You now you only bleed the top two nipples, not all four right?
Old Sep 18, 2004 | 09:28 AM
billyhoe's Avatar
18 Racing Hart CP-8's
Old Sep 18, 2004 | 09:29 AM
rapid_roy's Avatar
ATE Superblue
Old Sep 18, 2004 | 09:30 AM
billyhoe's Avatar
now i know to bleed only the top nipple, the brakes came with the car when i bought it thats why i didnt know how to do anything
mickey513
Nov 16, 2018 03:56 PM
dr_spock
Honda Civic (2001 - 2005)
Sep 20, 2008 10:22 PM
GQ Cowboy
30
Jan 3, 2003 12:39 AM
OEMaccord
13
Sep 20, 2002 11:08 AM
