Car Stutters When I accelerate
Old Sep 14, 2004 | 03:56 AM
PoPimpzrus's Avatar
Default Car Stutters When I accelerate
Yeha My Car stutters when i accelerate.. i dont know what it could be. can anyone help me on this.. i was wondering if the o2 sensor could cause this.. i know that the fuel filter can cause it. and bad plugs with bad wires can cause it.. but im pretty sure that my plugs and wires are still good.. i dunno though.. if someone can help. cause this is my daily driver.. have no other car to get to school and work
Old Sep 14, 2004 | 04:04 AM
01JDMIntegra's Avatar
Default Re: Car Stutters When I accelerate (PoPimpzrus)
i dont know if this wouldve helped me
i had the same problem, i went to the track and raced that weekend. Only thing i did was advace the timing a few degrees and now its gone? co incidence? very possible
Old Sep 14, 2004 | 06:16 AM
stareatsun's Avatar
disengage the clutch all the way?
Old Sep 14, 2004 | 08:16 AM
ponytd's Avatar
Default Re: (stareatsun)
it could be a number of things. pull out the plugs and see if they are black at the tips(how long have the pugs been in there aolong with the wires). try some fuel cleaner(or rubbing alcohol) and open it up on the interstate.
Old Sep 14, 2004 | 12:17 PM
DSR!'s Avatar
Default Re: (ponytd)
It's gotta be the tps sensor i had a similar problem
Old Sep 14, 2004 | 01:54 PM
Amkread's Avatar
Default Re: (DSR!)
broken motor mount/s?
Old Sep 14, 2004 | 03:47 PM
Mt3c's Avatar
25 Year Member
when you say "shutter", is it like the car is misfiring and kinda stalling. More like your hitting the gas, and the car engine just isn't moving the car.
i had a similiar "shuttering". Turned out that the screw that holds the rotor in the distributor came out, allowing the rotor to come loose. This lead to some misfiring, melted rotor, and a couple of shocked hands.
If you haven't done so in a while, replace your cap and rotor.
Old Sep 14, 2004 | 03:57 PM
hollaATyourBOY's Avatar
how many miles are on the car?
belts? clutch?
pork
Nov 11, 2007 08:20 PM
Junkyard2000
Jan 10, 2006 07:47 PM
tallguy
10
Aug 31, 2005 08:44 AM
coupey
Aug 19, 2004 03:13 AM
bokguay
Nov 15, 2002 10:22 PM
