p72 ecu for H22
Old Sep 13, 2004 | 10:05 PM
cal_'s Avatar
Default p72 ecu for H22
I recently had a mechanic friend of mine tell me that i should get rid of my chipped out p28 ecu and replace it with a chipped out p72 ecu. He said that the p72 is designed to also run the secondary butterflies in the intake manifold that both the Integra GSR and H22 share where as the p28 was not designed to do so. He said that if i got the p72 ecu i would notice a lot of hp increase when vtec kicks in. Is this all true?
Old Sep 13, 2004 | 10:38 PM
rev-speed's Avatar
no u will not feel a difference ur butterfly is already open when u full throttle
but u would notic a difference on part throttle daily driving
Old Sep 14, 2004 | 07:27 AM
b18cls1's Avatar
Default Re: (4cylinder)
why dont you modify the p28 ecu to operate the iab ive done it pleny of times,
Old Sep 14, 2004 | 07:39 AM
mmuller's Avatar
Mad Scientist
Default Re: (b18cls1)
it would make a difference, since your midrange is suffering because of having the sec. open all the time
Old Sep 14, 2004 | 09:40 AM
cal_'s Avatar
So it probly wouldnt be a bad idea to buy a chipped out p72 ecu then.
Old Sep 14, 2004 | 02:28 PM
freezyfreeky's Avatar
Default Re: p72 ecu for H22 (gsr778)
https://honda-tech.com/zerothread?id=567799
Old Sep 14, 2004 | 04:24 PM
h22 civic's Avatar
Default Re: p72 ecu for H22 (freezyfreeky)
p13
gorthjr
Sep 17, 2012 09:41 AM
Bmxlambis
Apr 4, 2009 07:19 AM
birwin12
Aug 3, 2007 10:21 PM
Slavko
May 9, 2005 08:41 PM
trans619
Jun 19, 2002 01:46 PM
