What kind of Studs, Bolts, Nuts etc... for Turbo Setup?
Old Sep 13, 2004 | 09:26 PM
silverb18's Avatar
Default What kind of Studs, Bolts, Nuts etc... for Turbo Setup?
Installing a turbo kit soon. I was planning on using studs and locknuts/washers to connect everything. I was going to use this:
10mm Studs for connecting the turbo/manifold with locknuts/washer
8mm Studs for connecting the turbo to downpipe with locknuts/washer
8mm studs for connecting the manifold to the block with locknuts/washer
Is this the correct way to do this install or should I use something else? Parts are revhard manifold, revhard downpipe, and t3/t4 turbo. I have read some people say no to use washers and to just use to locknuts on each stud, let me know what's up. Thanx.
Modified by silverb18 at 4:32 PM 9/14/2004
Old Sep 14, 2004 | 07:33 AM
silverb18's Avatar
Default Re: What kind of Studs, Bolts, Nuts etc... for Turbo Setup? (silverb18)
Any help?
Old Sep 14, 2004 | 09:25 AM
xenocron's Avatar
Contact Stan (Flemenco-T) on here.
http://www.fast-turbo.com
Old Sep 14, 2004 | 09:26 AM
V-SPEC 1's Avatar
search under flamenco-t , I think he's got all the list you're looking for.
Sprockets
Dec 4, 2011 07:15 PM
Charlie Moua
Nov 22, 2010 04:44 PM
lanojp1
Nov 2, 2004 05:50 AM
lanojp1
Oct 11, 2004 07:51 PM
hybrid901
Jun 27, 2003 03:43 PM
