axle question from auto to manual
auto and manual passenger side axle is the same. The driver side axle is different though. Remember that you need to the halfshaft, which is the piece between both axles.
i just changed my axles and the auto and manual shafts had different part numbers when i went to get them. but i think the passenger side is the same... dunno for sure. find someone with a manual and pop the sucker out lol. should take all of 30mins at most.
hmm.. confused... i don't know anyone around my area with a 93 accord with a 5spd tranny...
i'm thinking the driver side is the same and the passanger i would have to change... anyone else's imput?
Yup, its true, the driver side and the half shaft needs to be swapped out.
Have u check this site out, http://www.extremeredline.net/....html
Good luck with your swap, i gave up on mine.. just dont have the time to do it.
the drivers side u willl definitely need to swap, along with the intemediate shaft for it, but on the pass side, the auto axle will fit fine and work fine, though they are definitely different from the manual axle. They have differnt inner cv joint bearings, not really sure why, but thats the only difference i saw when taking them apart.
oh yeh, these guys are the goodness for your swap.. http://haprecycling.com/changeovers.html
Best thing to do is give them a call every now and then for those hard to find parts.
deeweezy187
Aug 6, 2007 01:01 PM
thisisntjared
Nov 18, 2002 06:21 PM
