94 auto to manual axle difference
Old Nov 18, 2002 | 06:45 PM
thisisntjared's Avatar
Default 94 auto to manual axle difference
I have a 94 dx that was converted to manual with the d16. The previous owner did not use a different tranny mount and this screwed up the axle. I got the right mount from Place Racing but the axle popped out again. Are the axles different from manual to auto?
Old Nov 18, 2002 | 07:15 PM
Desslok's Avatar
Default Re: 94 auto to manual axle difference (bleh)
I thought just the intermediate shafts were different, but I could be wrong.
Old Nov 18, 2002 | 07:17 PM
Default Re: 94 auto to manual axle difference (sp)
would that cause it to pop out?
Old Nov 18, 2002 | 09:26 PM
salbaje's Avatar
i have done the swaps and used the same axles maybe the axles were not seated in there properly.
Old Nov 19, 2002 | 05:48 AM
Desslok's Avatar
Default Re: 94 auto to manual axle difference (salbaje)
Did you replace the little retainer ring on the end of the shaft, and make sure that seats in when you push the axle in? It should be kind of hard to go in all the way, and then snap in place, and you shouldn't be able to just pull it back out by hand.
Old Nov 19, 2002 | 06:40 PM
replaced the seal. ill see how it is now. thanks.
twophastprelude
Aug 15, 2007 08:15 AM
idewson
Mar 2, 2006 05:20 PM
iongerz
Sep 14, 2004 07:59 AM
thisisntjared
Nov 22, 2002 08:22 PM
thisisntjared
Nov 18, 2002 06:21 PM
