What else do I need for Ls/Vtec?
Old Sep 13, 2004 | 02:03 PM
KustomCrx's Avatar
Default What else do I need for Ls/Vtec?
Ok, Im trying to get everything I can bought before I take the parts into a shop. They wont tell me what I need till they need it, so I can buy from them....so I'll write down everything I have, and everyone tell me what else I need(Gaskets, Sensors, ect...)
Vtec
Head
TB
Mani
ECU
Water Pump
Oil Pump
NonVtec
Block
Crankshaft
I know I need
Pistons
Rods
Oilpan
Harness
What else?
Please Help.
Old Sep 13, 2004 | 04:24 PM
EVOLUTIONINNYC's Avatar
new clutch, imo
block gaurd, imo
block girdle, imo
VTEC timing belt if your using a VTEC water pump. vice-versa
ARP head studs
B16 ECU
rod and main bearings
get everything balanced
i cant think of anything else. but it sounds like your set
oh and get I/H/E to
Old Sep 13, 2004 | 04:43 PM
limpy's Avatar
Default Re: (SiRhatchalot)
.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiRhatchalot &raquo;</TD></TR><TR><TD CLASS="quote">new clutch, imo
block gaurd, imo
block girdle, imo
ARP head studs
B16 ECU
oh and get I/H/E to</TD></TR></TABLE>
every thing he said but (imo) i don't think you need a block guard unless boosting or nos.
block girlde most definatly.
dont forget that if you do the vtec oil pump you need a vtec windage tray and pick up.
also recomend doing the arp rod bolts as well.
while you have everything torn appart i would also revomend doing a complete gasket kit.
Old Sep 13, 2004 | 09:11 PM
spyz34's Avatar
Default Re: (mrspeaker)
I have been looking for info regarding my lsvtec as well. What is the block guard that everyone talks about?
Edit: NM I searched
Modified by spyz34 at 10:22 PM 9/13/2004
Old Sep 13, 2004 | 10:18 PM
Fobtions's Avatar
block guard is garbage even on forced induction.
and the only thing i highly recommend is arp rod bolts, this is the weak link in Ls/vtec setups,
JDMCIVIC919
May 4, 2012 02:52 PM
nodamnnamesleft
Sep 10, 2005 05:50 AM
testingcheck
Aug 14, 2005 10:50 AM
crxhf19
Apr 15, 2005 10:53 AM
paulzy
Jun 27, 2001 11:06 AM
