Tranny removal!! PLEASE HELP!!!!
Old Sep 13, 2004 | 01:52 PM
6MTV6's Avatar
Default Tranny removal!! PLEASE HELP!!!!
Hey everybody. I'm pulling my Y1 on my B16, and putting in a YS1. I need some help on order of removal(what and when)to get the old one out. Please, please help. Thanks..
I also need helms info for torque specs on a YS1. I imagine all B-series cable trannies use the same torque. I'm not sure though.....
Modified by Bishop4G at 3:06 PM 9/13/2004
Old Sep 13, 2004 | 02:34 PM
6MTV6's Avatar
Default Re: Tranny removal!! PLEASE HELP!!!! (Bishop4G)
Bump
I'm trying to get this done after work today. Thanks.
Old Sep 13, 2004 | 03:19 PM
Cnote's Avatar
1. Disconnect battery
2. raise and remove wheels/tires
3. disconnect starter wires
4. disconnect tranny ground
5. disconnect VSS
6. remove tranny bolts and flywheel cover
7. remove clutch cable
8. drain tranny fluid
9. shift levers
10. ball joint nuts
11. lower shock forks bolts
12. take out axles
13. remove two rear mount bolts
14. drop tranny
15. remove Pressure plate, clutch disk
16. remove flywheel and resurface
17. replace Throwout bearing and pilot bushing.
98vtec
Dec 4, 2008 01:49 PM
arielb1
Oct 31, 2008 12:03 PM
89bluehatch
Mar 3, 2007 12:53 PM
jovial111
Dec 22, 2003 08:23 PM
TeAm IllUsIonZ978
Nov 1, 2002 03:19 PM
