Waht can it be, car jerked on highway
Old Sep 13, 2004 | 06:23 AM
EF4lyfe's Avatar
Default Waht can it be, car jerked on highway
I was driving down the highway this morning, i was doing about well i dont know but i was in 5th at 4500 rpms and the car jerked and when i gave it gas is wouldnt go, but then all of a sudden just started working within seconds. I got a check engine light and got the same code that i had before 7 which is TPS throttle position sensor, what could this problem be, still showing cel?
Old Sep 13, 2004 | 07:25 AM
EF4lyfe's Avatar
anyone?
Old Sep 13, 2004 | 07:40 AM
91civicEX's Avatar
Default Re: (SIhatch90)
reset the ecu? could be a bad connection that vibrated loose
Old Sep 13, 2004 | 09:15 AM
crx_88_si's Avatar
lol maybe the TPS sensor is out of spec.
Old Sep 13, 2004 | 09:20 AM
MENACE's Avatar
Default Re: (crx_88_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si &raquo;</TD></TR><TR><TD CLASS="quote">lol maybe the TPS sensor is out of spec.</TD></TR></TABLE>
Old Sep 13, 2004 | 03:32 PM
eumoria's Avatar
Default Re: Waht can it be, car jerked on highway (SIhatch90)
maybe you just forgot to print the cover sheets on the TPS reports
Old Sep 13, 2004 | 04:00 PM
B16 CRX's Avatar
Default Re: Waht can it be, car jerked on highway (eumoria)
Check you TPS, there is a thread on HT which explains on how to check the TPS do a S-E-A-R-C-H
Old Sep 13, 2004 | 04:02 PM
mengo_charged's Avatar
Same thing happened to me, but it was after I pressure washed my engine bay. It went away for me, maybe because it finally dried up in there. In your case, check your TPS...
cprlover
Dec 7, 2010 04:35 PM
EJ1 Type Slow
Jul 28, 2007 12:24 PM
Civic4less
May 31, 2005 07:14 AM
hondaeg8
May 14, 2004 10:23 AM
MassScene
Apr 27, 2004 05:08 PM
