K20A swap in a DC2: Thoughts and suggestions please
Old Sep 13, 2004 | 12:07 AM
jonyb's Avatar
Default K20A swap in a DC2: Thoughts and suggestions please
I did a search and only found eg and ek swaps.
Thinking of doing this in my DC2. I've got a JDM ITR swap in it now. Are there any kits and what all is required? If anyone has a link to a thread post it here. Thanks in advance.
Old Sep 13, 2004 | 04:33 AM
Dngerzone2's Avatar
Default Re: K20A swap in a DC2: Thoughts and suggestions please (jonyb)
https://honda-tech.com/zerothread?id=962600
try PM'in one of these guys about your swap
Old Sep 13, 2004 | 04:36 AM
Stinkycheezmonky's Avatar
Suspetise...
JoeSTypeS has been in the process of doing it, and has been finished for awhile now (I think). https://honda-tech.com/zerothread?id=844044
Old Sep 13, 2004 | 01:04 PM
vtec.dc2's Avatar
i've read through all threads, my concern is oil pan clearance. how low would it be with stock height of gsr/itr and can it be fixed?
Old Sep 13, 2004 | 01:18 PM
kmar111's Avatar
Default Re: K20A swap in a DC2: Thoughts and suggestions please (vtec.dc2)
i have the k20a hasport kit is my dc2 and i have not had any problems with the oil pan hitting anything and i live in an area that teh roads are really bad. so it really is not that serious.
Old Sep 13, 2004 | 01:21 PM
vtec.dc2's Avatar
Default Re: K20A swap in a DC2: Thoughts and suggestions please (kmar111)
so.. how much lower is it that stock? .. or whats the clearance for oil pan in your case?
Old Sep 13, 2004 | 01:27 PM
Nvious R's Avatar
From: Bitch Slapping Your Ass Around The Twisties n Doin, it Doggy style At a theater near you
would an aftermarket oil pan help? I wonder if they make ones with better ground clearances. I doubt it though since an aftermarket is supposed to be designed for MORE oil capacity = larger tank. I dont' think the clearance issues would be worse than lets say... a 4-1 exhaust manifold?
Old Sep 13, 2004 | 01:29 PM
Jon V's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jonyb &raquo;</TD></TR><TR><TD CLASS="quote">I did a search and only found eg and ek swaps.
Thinking of doing this in my DC2. I've got a JDM ITR swap in it now. Are there any kits and what all is required? If anyone has a link to a thread post it here. Thanks in advance.</TD></TR></TABLE>
There is lots of info on this swap on this site. Search
if you need a little more help try K20a.org
be ready to spend some money too...
Old Sep 13, 2004 | 02:48 PM
jonyb's Avatar
Default Re: K20A swap in a DC2: Thoughts and suggestions please (Jon V)
The problem with the info that I found is that it was from April and the earlier months of the year. It's September now. I was just looking for some up-to-date information and new products that weren't available back then.
Thanks for all of the replies
Old Sep 13, 2004 | 02:53 PM
Suspetise...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.dc2 &raquo;</TD></TR><TR><TD CLASS="quote">so.. how much lower is it that stock? .. or whats the clearance for oil pan in your case?</TD></TR></TABLE>
I've also been wondering about the oil pan clearance. I mean, I don't have the money anyway, but if I were ever GOING to do it, that would be my primary concern.
Old Sep 13, 2004 | 05:34 PM
Dngerzone2's Avatar
Default Re: K20A swap in a DC2: Thoughts and suggestions please (sscguy)
i think theres enough clearance even with the car lowered.
Old Sep 13, 2004 | 05:42 PM
kmar111's Avatar
Default Re: K20A swap in a DC2: Thoughts and suggestions please (Dngerzone2)
i have the type-r front lip and it is about 2-3inches off the ground so just about a 2.50 drop.
Old Sep 13, 2004 | 06:27 PM
Suspetise...
Can you take some pics from the front showing the oil pan clearance?
Old Sep 13, 2004 | 09:06 PM
kycivicboy's Avatar
i believe i read once that the eg mounts would work with the dc2. back when i was studyin up to do the swap in my ek. never went through with it though. too much trouble and money.. but i say go for it and after u do the swap if i dont sell my car i will let u help me don one on mine
Old Sep 14, 2004 | 01:35 AM
Stunna BEN's Avatar
Don't call it a comeback
Default Re: K20A swap in a DC2: Thoughts and suggestions please (kycivicboy)
DO it! EG mounts work. PLEASE do it. I wana see more!
Old Sep 14, 2004 | 02:12 AM
:jdmshmaydm:'s Avatar
Default Re: K20A swap in a DC2: Thoughts and suggestions please (Stunna Ben)
So EG mounts work then? What else is a concern aside from the oil pan clearance. Loss of A/C?
Old Sep 14, 2004 | 06:17 AM
Jon V's Avatar
Default Re: K20A swap in a DC2: Thoughts and suggestions please (Gatecrasher20AF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gatecrasher20AF &raquo;</TD></TR><TR><TD CLASS="quote">So EG mounts work then? What else is a concern aside from the oil pan clearance. Loss of A/C?</TD></TR></TABLE>
and PS...
but is that really a concern?
I would say from all the cars i have seen oil pan clearance is about 5-6 inch's maybe a little more. I don't think it is all that bad. You just have to remember that it is there.
The EG and DC kit has better axle angle, and is placed a few inches further back and higher in the engine compartment, giving it a slight advantage over the EK kit in oil pan clearance (this is because of the steering rack and front crossmember in the EK), and also in weight distribution. It also helps if you are doing a K24 swap and you need the little extra room.
Old Sep 14, 2004 | 06:20 AM
Nikos's Avatar
This is a pdf version of the instructions you get when you buy the hasport mounts.
Save as
http://www.k20a.org/EGK1.pdf for 92-95 EG
http://www.k20a.org/EKK1.pdf 96+ EK
I found the instuctions here :
http://hasport.com/Tech/Hasport%20.htm
and mirrored them on my server
Thank you hasport for taking the time to outline the swap. Also I like how they take the time to include which size tool you need for each step.
globy123
20
May 25, 2007 02:40 PM
jdmcrx_echelon
Jul 19, 2006 07:12 PM
1badda
May 2, 2006 01:03 PM
Alexander
Dec 20, 2005 08:34 PM
