Titanium
Old Sep 12, 2004 | 11:40 PM
tianporn's Avatar
Default Titanium
Hi,
You know the bluey burnt tinge on titanium mufflers? Is it possible to make any other metals this colour or similar or does it have to be REAL titanium?
Cheers
Old Sep 12, 2004 | 11:50 PM
Ekasey's Avatar
Default Re: Titanium (tianporn)
I have heard of certain places being able to it with coating not too muhc more info then that though
Old Sep 13, 2004 | 03:28 AM
tianporn's Avatar
Default Re: Titanium (eLusive ek4)
Yeah just wondering if any of those cheapass "titanium" tip mufflers from ebay are actually titanium.
Old Sep 13, 2004 | 03:32 AM
Brandon Clifton's Avatar
For iron, but the temperatures are similar for steel and Ti.
http://www.lyttoncreek.com/spon.gif
Old Sep 14, 2004 | 12:03 AM
tianporn's Avatar
Default Re: Titanium (Brandon Clifton)
Does this look titanium?
Old Sep 14, 2004 | 12:18 AM
Ekasey's Avatar
Not especially hard to tell looks more like polished stainless
Old Sep 14, 2004 | 02:18 AM
tianporn's Avatar
Oops im just talking about the tip. You see the blue tinge? I thought you cant do that to stainless.
Old Sep 14, 2004 | 07:12 AM
Ekasey's Avatar
Yeah as far as i know you can't but you also cannot weld Ti to Stainless either
Old Sep 14, 2004 | 08:19 AM
eLUDEnu
Guest
Posts: n/a
looks like a stainless muffler and somebody took a torch and heated it up.
Old Sep 14, 2004 | 10:48 PM
tianporn's Avatar
Default Re: Titanium (eLUDEnu)
Cool thank. I guess its "titanium tip style"
Old Sep 15, 2004 | 01:09 AM
01geeser's Avatar
New User
i think you should be able to torch up stainless for the look. ever look at a polished stainless manifold or a stainless dc header?
Old Sep 15, 2004 | 02:31 PM
carbonDelSol's Avatar
Default Re: Titanium (01geeser)
Yeah, just use some WD-40 and then come heat, that combo should do it.
Old Sep 15, 2004 | 10:18 PM
rjay8604's Avatar
Default Re: Titanium (carbonDelSol)
I must admit, the bluing on SS and titanium does look cool as hell.
Old Sep 15, 2004 | 10:32 PM
L-CON1's Avatar
you can definately get that color from stainless with a torch. best to use a small butane torch like the ones used for brazing from home depot.
Old Sep 15, 2004 | 11:29 PM
tianporn's Avatar
Default Re: Titanium (fab1)
So what... spray WD40 on it and just torch it up with a small butane torch? Im assuming you can do this to 304 and 306 stainless steel?
Just another question, will the colour eventually come off or like change to a crap colour? Then would I just repeat the process again?
Old Sep 16, 2004 | 01:10 AM
L-CON1's Avatar
havent tried it with wd40! i just used the torch.
Old Sep 16, 2004 | 04:44 PM
SuperTuner's Avatar
Just send me $60 and I will send you a burnt tip ss muffler.
Old Sep 16, 2004 | 10:07 PM
eHoward's Avatar
you can scotch weld it
Old Sep 18, 2004 | 01:14 PM
dmotoguy's Avatar
Default Re: Titanium (eHoward)
my titanium exhaust was a pretty blueish purple.. but it slowldy faded to a grey/blue after a while..
Old Sep 18, 2004 | 11:40 PM
TurblowR's Avatar
Default Re: Titanium (dmoto)
my apexi full catback exhaust now has a gold tint on the tip. tried to get it off but its premenetly on there. looks pretty cool.
Old Sep 19, 2004 | 03:55 AM
TeamNextGenChris's Avatar
a couple years ago i had an X-Tec stainless muffler on my hatch.i used a torch to turn the whole can a goldish color,with a blued tip.pretty easy;i was using a full-blown cutting torch,just have to be careful with how much heat you apply.
Chris
Old Sep 21, 2004 | 12:57 PM
jisu009's Avatar
Default Re: Titanium (TeamNextGenChris)
So here is a question:
How do you attach a full Ti muffler to stainless tubing? T-Bolt clamp?
Old Sep 21, 2004 | 02:30 PM
Default Re: Titanium (jisu009)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jisu009 &raquo;</TD></TR><TR><TD CLASS="quote">So here is a question:
How do you attach a full Ti muffler to stainless tubing? T-Bolt clamp? </TD></TR></TABLE>
all the systems i've seen with some kind of steel midpipe and ti muffler have the muffler slip fit on the midpipe with a clamp securing it.
Chris
Old Sep 21, 2004 | 06:44 PM
jisu009's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamNextGenChris &raquo;</TD></TR><TR><TD CLASS="quote">
Chris</TD></TR></TABLE>
Do you "slit" the slip fit? or just clamp it down tight as a virgin in a traffic jam?
Old Sep 22, 2004 | 03:23 AM
Do you "slit" the slip fit? or just clamp it down tight as a virgin in a traffic jam?</TD></TR></TABLE>
all i've seen have slits on the slip-fit section.
Chris
