what is a chipped ecu?
Old Sep 12, 2004 | 11:14 PM
yeegsr's Avatar
Default what is a chipped ecu?
im so sorry man....call me noob as if you wish
all i know is bolt on stuffs...nothing to do with ecu...when i was reading some posted thread,,,people were talking about chipped ecu with vafc (vtec something fueling control?) or vtec controller (what i know), wat have no idea wtf is chipped ecu
but wat is chipped ecu? wat does it do? is it pricey? worthy to get? i got i/h/e completed what should i get next?
Old Sep 12, 2004 | 11:15 PM
yeegsr's Avatar
Default Re: what is a chipped ecu? (yeegsr)
oh yeah forgot to tell you guys,,,i am running a 97 GSR....i heard about p28 or hondata s200 or s100..one of them i can't use because my model is 97 gsr is that true
Old Sep 14, 2004 | 10:40 AM
jwaked's Avatar
First of all, hahahhahahhahaha for that question. YOu are lucky no one has gotten on your case. With that said.
I chipped ECU is when someone works on the stock honda ECU and replaces the stock chip with a chip that has another program (skunk, mugen, custom, etc). some of them give you more gas, more timming, etc and make your engine produce a little more HP. This is just the simple explanation.
Should you get one? SUre, its another bolt on. Try Erick Racing, he will tell you what to do and how or whats best for your needs.
Old Sep 14, 2004 | 11:54 AM
h22avid's Avatar
Default Re: what is a chipped ecu? (jwaked)
Way to give a decent response without ripping the admitted noob a new one
Old Sep 14, 2004 | 07:03 PM
yeegsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jwaked &raquo;</TD></TR><TR><TD CLASS="quote">First of all, hahahhahahhahaha for that question. YOu are lucky no one has gotten on your case. With that said.
well nothing bad to be a noob i guess....i just wanna know more and more by asking question....no point of being a noob and not asking question...then that will be all time noob lol...
yeah i know chipped ECU someone is chipped ECU but chipped with what is what i need to know and there you answered (skunk2, mugen, custom...etc for more timing, gas...etc...)thanx for trying...nothing embrassing for me..as long as i know somethign more...
Old Sep 14, 2004 | 07:04 PM
yeegsr's Avatar
btw...you got any suggestion for ECU upgrading for my 97 gsr...? hondata...mugen? how much are those going for anyway....
Old Sep 14, 2004 | 07:31 PM
DefiantGSR's Avatar
not much for just bolt ons..you wont gain much on a bolt on GSR.
Old Sep 29, 2004 | 07:25 AM
R-Toyz.com's Avatar
If you want to run a chipped ECU, you will have to buy a conversion harness (obd2-obd1) then buy yourself an OBD1 ECU which can then be chipped and re-tuned for your motor. Depending on the program you can get decent gains even on a stock motor.
Old Sep 29, 2004 | 07:53 AM
NAstreetEH2
Guest
Posts: n/a
http://www.pgmfi.org
Old Sep 29, 2004 | 11:36 PM
yeegsr's Avatar
Default Re: (rtzcom)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rtzcom &raquo;</TD></TR><TR><TD CLASS="quote">If you want to run a chipped ECU, you will have to buy a conversion harness (obd2-obd1) then buy yourself an OBD1 ECU which can then be chipped and re-tuned for your motor. Depending on the program you can get decent gains even on a stock motor.</TD></TR></TABLE>
why? how come it turns out so much hassle and pricey? is it because my motor is 97?
Old Sep 29, 2004 | 11:37 PM
yeegsr's Avatar
Default Re: (yeegsr)
bump, bump
Old Sep 30, 2004 | 03:17 AM
NAstreetEH2
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yeegsr &raquo;</TD></TR><TR><TD CLASS="quote">why? how come it turns out so much hassle and pricey? is it because my motor is 97?</TD></TR></TABLE>
that's not a hassle or pricy.
and yes, you have an obd2a ecu...and until flashable chipping becomes readily availble..you're stuck converting to obd1
Old Oct 7, 2004 | 08:03 PM
yeegsr's Avatar
Default Re: (NAstreetEH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAstreetEH2 &raquo;</TD></TR><TR><TD CLASS="quote">
and yes, you have an obd2a ecu...and until flashable chipping becomes readily availble..you're stuck converting to obd1</TD></TR></TABLE>
and when is the flashable chipping becomes readily avaliable? not yet for a while
ryanevansoh
Jan 13, 2009 08:50 PM
green91
May 1, 2008 05:36 AM
91d15bvtec
May 11, 2005 03:57 PM
