car wont start...bogging..CEL *flashing*
Old Sep 12, 2004 | 10:48 PM
ekfighter's Avatar
Default car wont start...bogging..CEL *flashing*
I have a 96 hb with b18c1 swap...just put a new fuel pump in(Walbro 255) and car ran fine for a few days and tonight it starting bogging super bad and finally it died and wont start again...Im getting spark and I can hear fuel pump come on but it wont turn over. Any ideas would be greatly appreciated. Also I think O2 sensors are not wired correctly because Im throwing O2 codes and CEL was on prior to fuel pump install. My spark plugs also had oil on them .
Old Sep 12, 2004 | 10:53 PM
JDMlyfestyle's Avatar
have any new codes pop up?
Are all the engine grounds making a good connection?
battery
thermostat
Head
Tranny.
Also it could be the main relay
Old Sep 13, 2004 | 04:26 AM
Luserkid's Avatar
Default Re: (JDMlyfestyle)
If the O2 sensor isnt wired up that wouldnt cause your car not to start. Check your fuses, mainly this one:
Does the car even crank or it doesnt even do that? Also oil on spark plugs is never a good sign. How old is the motor and where did you get it from? run a compression test.
Thats just all the stuff i would do off the top of my head. Hope that helps.
Old Sep 13, 2004 | 04:51 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: car wont start...bogging..CEL *flashing* (ekfighter)
the check engine light flashing is a mifire related code. actually it is a catalyst harming failure. just if you needed toknow why it is flashing.
Old Sep 18, 2004 | 02:20 PM
ekfighter's Avatar
Default Re: car wont start...bogging..CEL *flashing* (boostedcivicsir)
It was my fuel pump....thanks for the information. No fuel=misfire. Thanks again.
BSERIESDARRYL
Apr 15, 2017 07:27 AM
xxzombierot
Mar 10, 2013 09:53 PM
spoolinb18
Feb 21, 2012 06:13 AM
quad
20
Mar 14, 2007 05:16 AM
dogbiscuit
16
Oct 28, 2005 04:59 AM
