Differences??
the restrictor plate is under the throttle body cover right. cuz if it is i took that out so all i would need is a d15b2 cam and ecu and i can gain 20hp in theory?
I've never heard of the restrictor plate b/c i rock b-series.
So i searched restrictor plate. Check out 91civicdxdude's post.
https://honda-tech.com/zerothread?id=636167
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrspeaker »</TD></TR><TR><TD CLASS="quote">just do mpfi swap</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pSI civic »</TD></TR><TR><TD CLASS="quote">i thought the b1 was carbed.</TD></TR></TABLE>
The d13a2 (not a typo) made in 1987 was the last carbed civic motor. The fuel pressure is 3 psi. It used a mechanical fuel pump.
You are correct. They simplified everything for the 90-91's and stopped making that header-cat combo for the Sexually Transmitted D-Series a.k.a. D15B1. However, the engine did not change so you can put the 90-91 cat-under-the-car style on your 88-89 although it doesn't make a difference in anything.
i have the b1 but from 88
My b1 has the turbo-looking manifold too. And boy does that cam stop making anything happen after 6.2k. OOOO boy. ::dies::
Todd00
50
Apr 22, 2005 04:42 PM
