Valve springs tool?
Old Dec 8, 2001 | 03:56 PM
SpeedracerS4's Avatar
Default Valve springs tool?
I wanted to swap my valves, valve springs and retainers. I did once borrowing a tool from my friend, its like one of those thing you hook up on top of the head and then you can compress the spring and use a pick to take out the keeper. But now I want to get one of my own, any1 know what is that tool called>? or where can I get it at?
Old Dec 8, 2001 | 04:12 PM
FSTASNTZ's Avatar
Default Re: Valve springs tool? (SpeedracerS4)
Snap On sells a good one. It is just a Honda Valve Spring compressor...
Jason
Old Dec 8, 2001 | 08:43 PM
yeah i think i found it over at their website, pretty spendy though
Old Dec 8, 2001 | 10:37 PM
smerk's Avatar
New User
These 2 are almost the same tools but cheaper:
http://www.etoolcart.com/product.asp?0=203&1=215&3=1046
http://www.etoolcart.com/product.asp?0=203&1=215&3=385
I've been looking into replacing my springs/retainers also. Any tips? I looked at the factory manual and it looks like the valve keepers will be tricky to remove. I want to do this with the head still on and I don't want them to drop or lose the keepers.
Old Dec 8, 2001 | 10:43 PM
Default Re: Valve springs tool? (smerk)
I usually do it with a help from someone, while I carefully compress the spring the other person grab the keepers using a magnet. That usually work, but becarefull not to drop the keepers, its impossible to find it.
Old Dec 9, 2001 | 12:07 PM
martini's Avatar
There's no readon you can't make your own compressor. I had been searching for one, but read in a magazine article about Team L'Natural using a compressor that they made themselves...and got to thinking about it. It's a really simple device.
Old Dec 10, 2001 | 03:06 AM
LX02's Avatar
You're doing this with the head on the car? Don't forget you need to pressurise the cylinder to stop the valves dropping down.
LX02
"But Lisa! Just because I don't care doesn't mean I don't understand!" -Homer J. Simpson
Old Dec 10, 2001 | 04:27 PM
smerk's Avatar
New User
Default Re: Valve springs tool? (LX02)
I was thinking of just rotating the crank and move the piston up to stop the valves from dropping all the way down.
Old Dec 11, 2001 | 04:37 PM
LX02's Avatar
I wouldn't do it that way. You'll find it very hard to compress the springs far enough to get the collets on. Remember that the valves don't normally go down that far. Braze an air fitting onto a cut-up old spark plug and hook a compressor up.
LX02
"But Lisa...just because I don't care doesn't mean I don't understand!" -Homer J. Simpson
hella_brr_da
Aug 26, 2012 12:06 PM
danthemang3
Jan 16, 2006 06:02 PM
sleepin91teg
Jun 20, 2004 05:34 AM
funkylemons
Feb 22, 2003 11:27 PM
ITRfaithful
Feb 19, 2003 04:05 PM
